if you used ARP studs I'm pretty sure they need more torque then the stock head bolts. Here's the directions from ARP.
http://arpinstructio...ns/244-4300.pdf
Automotive Racing Products Tel: (805) 339-2200
1863 Eastman Avenue Fax: (805) 650-0742
Ventura, Ca 93003 www.arp-bolts.com
INSTALLATION METHOD FOR HEAD STUD KITS
Part Number: 244-4300 Application: Chrysler 5.7L/6.1L Hemi
1. Always verify the part number for your application with the part number on the side of box and the part
number on the instruction sheet. This will help ensure you have the correct installation procedure for
your specific application before installing any components.
2. Clean and inspect all hardware prior to installation. Look for obvious defects or shipping damages, plus proper fit,
length and dimension.
3. To ensure proper thread engagement and accurate torque readings, clean ALL threads in the block. Chase if
necessary with ARP Thread Chaser, part number 912-0007 (M12 X 1.5).
4. If the cylinder head studs protrude into a water jacket, lubricate the block threads of the studs with ARP THREAD
SEALER.
5. Screw studs into the block “HAND TIGHT ONLY”.
NOTE: LOCTITE MAY BE USED IF A PERMANENT MOUNTING OF THE STUDS IS PREFERRED. THE
FASTENERS, HOWEVER, MUST BE TORQUED PRIOR TO THE LOCTITE SETTING UP.
6. Install the cylinder head(s) and check for binding or misalignment.
7. Lubricate the stud threads, nuts and washers with ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT.
Then install the washers and the nuts onto the studs and tighten them hand tight. ARP recommends using the
ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT that is provided with each kit as opposed to
motor oil. This is due to higher friction on the studs as well as inconsistencies in the clamping force of
the fasteners when motor oil or other low quality lubricants are used.
PRELOAD (TORQUE) RECOMMENDATIONS
8. Following the manufacturers recommended torque sequence tighten the nuts in three equal steps to the
following specifications with ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT.
M12 studs (1-10) 105 ft lbs M8 studs (11-15) 25 ft lbs
Note: ARP Ultra-Torque Fastener Assembly Lubricant has been specifically designed to reduce tension preload scatter and
eliminate the need to cycle high performance engine fasteners before final installation. ARP Ultra-Torque far surpasses all
requirements offered by previous ARP lubricants in terms of fastener preload repeatability and performance lubricating
properties. For more information on ARP Ultra-Torque visit our website at www.arp-bolts.com or call 1 800-826-3045.
Bolt Torque Sequence
3/7/11
