This should address this issue and hopefully give the customers a case to present to Diablo Sport. The Issue is in a 2006 car with a 2009 and up PCM no logging is available where in the past it was. What it looks like is happening now is that the ability to read and display PID's is now a populated by PCM Vin number rather than Cal ID as is was in the past. I am lead to believe by one of the customers affected that Diablos position is that Because of the custom programming on the PCM by API that we are implanting the issue.
I Have Pictures and proof but the forum will not allow me to upload pics from Photo bucket. You can use this link to get the Pictures.
http://s860.photobuc...866531907599398
What you are looking at is my portable flash cord hooked up to my power supply in my office. For this excersise I took an UNMARRIED Trinity that is Main-Lined into the Can C BUS wires via Pin's 6 and 14 of the DLC. With the same Cal ID, Trinity, And PCM you can see that when the 2009 Vin is entered the PID's in the 2007 Tuner Dash pull up and display just fine. When the 2006 Vin is installed they show up undefined. In the past Diablo always populated the logging via Calibration ID not by VIN. It seems that has changed. Hopefully it is an Easy fix for them to set it back and finds this thread helpful.
Thanks
AJ
