Afr Functional Shaker Scoop Vs Lmi
AFR shaker LMI
9 replies to this topic
TNCHARGER
TNCHARGER
  • 242 posts
I posted this a couple weeks ago on the LXF and forgot to post here...
Took my car to Arrington a few weeks ago to get an initial dyno tuning for the 6.4 based 426 stoker in my car. AJ (aka Hemituner) dynoed the car and worked on the tune. He managed 468 RWHP and 515 RWTQ at that time. He told me he wanted to do some R&D from the data he took from the dyno runs (my car is the beta test for the 6.4 based 426). I then took the car back home 3 hrs away.
AJ mentioned that he wanted to try a pull with the AFR Shaker unhooked from the throttle body when I returned for final tuning. He felt like there were some air flow restriction at the higher RPMs. When I got home I modified the AFR so I could install the LMI True CAI and still retain the shaker hood scoop on the car.
A few weeks later AJ said he was ready to do the final adjustments and would need the car for several days. I dropped the car off Tuesday and returned home. The next day AJ did a dyno pull before adjusting anything to see if anything had changed. Something had changed...a lot.
The car gained 28 RWHP since the last dyno session. Nothing had been changed except for the LMI CAI being added in place of the AFR Shaker duct to the throttle body.
The red line represents the first dyno and the black line the current dyno with the LMI CAI. The peak torque dropped about 3 points but you will notice the torque line is flatter and doesn't fall off as quick as RPMs increase. The slight decrease in peak torque may be explained by air speed being increased at lower RPMs due to the restricted AFR ducting but choking off air flow at higher RPMS.
This post is not meant to say the AFR Shaker is poorly designed. The duct design of the AFR is probably as good as it gets for the amount of space available. The other brands (Danko, Cervis) may have similar issues with their functional scoops.
I just wanted others to know that they may be leaving 2-3 tenths on the plate at the track. My AFR Shaker is still functional only it cools the engine compartment instead of supplying air for the engine....The LMI is doing a great job at that..
Final dyno numbers: 513 RWHP / 517 RWTQ (Video link>> https://www.youtube...._KICA_-afaw#t=8 )... :P
2013 CHALLENGER SRT8 AUTO IN BLACK * LMI TRUE CAI * KW COIL OVERS * CORSA EXTREME CATBACK * MAGNAFLOW MID W/ HIGH FLOW CATS * 3.23 GETRAG LSD * PARAMOUNT DOMINATOR 3800 STALL CONVERTER * SPEEDLOGIX REAR SEAT DELETE * SPEEDLOGIX LIGHTWEIGHT FACIA AND REAR BUMPER MOUNT * ARRINGTON 6.4 BASED 426 * TUNED BY THE HEMITUNER * 6.1 ALUMINUM INTAKE * 517 RWHP / 536 RWTQ......MORE TO COME...
PB QUARTER MILE 11.674 @ 118.32MPH 1.602 SIXTY FOOT WITH MT 305/35/20 DRAG RADIALS....
legmaker
legmaker
    100 hp intakes
  • 814 posts
nice......
10.06 @ 140
Hemi57
Hemi57
  • 4,006 posts
Photos of the before and after mods to the air intake?
2010 Stone White R/T
TNCHARGER
TNCHARGER
  • 242 posts
This is before I removed the box (circled) that connected to the tube running to the throttle body.
...I don't have a picture of after the box was removed but it is in the dyno video..  http://api.viglink.c..._KICA_-afaw#t=8
  • 17,071 posts
Very nice
PWR 426 D1 Procharged
10.537@131
sharkcohen
sharkcohen
    Captain Hindsight
  • 2,788 posts
Very nice! And no surprise. Good call on AJ's part.
rudedog
rudedog
  • 299 posts
Do you have any pictures of the underside of the shaker?  I see this is the 392 version.  I wonder if there is less, more or the same with the older style.
Here are some pictures of mine.
Not so Rude - Rudedog
2010 Challenger R/T Classic | Plum Crazy Pearl | 6sp | sun roof | STP | Leather | Sound Group II w/Nav (730N) | functional hood | Hood struts | Mopar fender flairs | Charger Clean Air Intake w/ K/N | Lockpick v.4 w/cam | Petty Garage STB | custom eng cover | Trinity 1r10g.crom | BBK 85mm ported and polished TB | Hust S/T shifter | BT Catch can|engine bling | PASSPORT Qi45 | AFR shaker/TA functional hood | A/N braided hoses | JBA headers | Magnaflow high flow cats | high band 02 and gauge
TNCHARGER
TNCHARGER
  • 242 posts
The filter looks the same. The only difference between yours and mine is the throttle body connection. The air flow in the 392 version has to make three 90* turns on it's way to the throttle body. Because of the air turbulence that would result slowing air speed is probably why the big difference in HP in the upper rpms.
nolimits76
nolimits76
    Jack & Diet
  • 984 posts
I know Wes had some issues with his Cervini.  Here is a post from his website about it.  I thought Dale had similar issues and a similar fix.
http://rippinit.com/...rvinis-ram-air/
2014 Ram Sport QC 4x4, 8-speed
2013 Charger SXT, 8-speed
2010 Challenger RT, 6-speed (retired)
Hemi57
Hemi57
  • 4,006 posts
The problem with the Cervini is the size of the air filter. I cut the air box to TB tube off and used a 4" S&B air filter and a DIY connecting tube. There is a writeup in the Knowledge base on how I did it.
