Is there a simple fix for breaking that nipple off besides buying a replacement intake? Anyone know what kind of plastic it is? Probably PA66? JB Weld indicates that it doesn't bond well to:
- Polypropylene plastic
- Polyethylene plastic
If it's PA66, will it bond well enough for 8 psi of boost? I stuck it on there last night and checked it this morning, and it seems to be setting up okay. I'm just nervous of it failing after a good boosted run then needing to get on the brakes and having no power brakes.
Would a better option be to plug that hole with a bolt and some sealant, then tap into the PCV line coming from the top of the manifold and run that to the brake booster?
