Header Gaskets???
11 replies to this topic
lanceschallenger
lanceschallenger
  • 48 posts
Hey guys!!! Needing a pair of header gaskets. Whos are you using? Need to put in an order today to shut the leak up this weekend.
Thanks for your input.
Lance
are you using aftermarket headers? did you not use factory gaskets when you installed?
driver side 53032965AF
passenger side 53032966AF
lanceschallenger
lanceschallenger
  • 48 posts
I have a LT on it an ran the paper gaskets...finally blew out. Never even payed attention to the factorys I removed, though I do still have em. Will they seal if I reuse?? They r inexpensive new, I understand. I am in a small town and everything has to be ordered. So, if I could run em I would.
Thanks
Guest_HemiRob_*
Guest_HemiRob_*
most gaskets are a one time use, the used ones will most likely not seal properly and will leak.
lanceschallenger
lanceschallenger
  • 48 posts
Ya, I can see from pictures that the factory has a squench area and the manifolds have already compressed it completely. I will put an order in then. Thanks guys!
lanceschallenger
lanceschallenger
  • 48 posts
Lucky...dealer 14 miles down the highway had em! 1 set in special order bin for "no show" customer!
  • 18,480 posts
Lucky is good.
Jay6spdRT
Jay6spdRT
  • 10,833 posts
Lance, make sure you thoroughly clean all the old gasket material off the heads before installing gaskets and headers. Good luck.
Guest_HemiRob_*
Guest_HemiRob_*
you did get really lucky finding them in stock, be sure to torque the header bolts to the proper torque spec. i agree with Jay6speedrt with scraping and cleaning off the old gasket material off the headers and do the same on the cylinder heads to insure a proper seal and to prevent leaks.
lanceschallenger
lanceschallenger
  • 48 posts
Will do! Thanks guys!!
  • 18,546 posts
Getting ready for the Mile, Lance?
lanceschallenger
lanceschallenger
  • 48 posts
As of now, I am up in the air. How bout you SAM?
