Trans Brake Needed Or Not
Posted 22 May 2011 - 07:13 AM
Tout
2011 Dodge Challenger Dragpak 8.54 @152mph single 250 shot MPH Racing Tim Barth Arrow Racing Engines, holds the Fastest 1/4 mile Time slip.
2015 White Hellcat Challenger auto,[email protected] High Horse Performance Josh Fastest in the country
Bill, you owe me $8300.00 for the Rossler TH210 trans you stole, can't wait to see the day when the guy's you have your grubby hands in their pockets figure you out for the thief you are.........I wouldn't do business with anyone that you are associated with, thieves always hang together..............
Posted 22 May 2011 - 07:16 AM
Posted 22 May 2011 - 07:23 AM
Posted 22 May 2011 - 07:29 AM
Tout
Posted 22 May 2011 - 07:30 AM
Posted 22 May 2011 - 07:31 AM
Posted 22 May 2011 - 07:33 AM
Posted 22 May 2011 - 07:34 AM
MikeJohns never worked right. To make it work you have to use an MSD rev limiter to set your launch RPM. Problem was it would also kill the timing all the time. Could have been installation error (not John) or something else. All I know is it killed the car on the dyno. He lost over 100hp until it was disconnected.
They also talk about a two stage rev limiter in this conversation
Posted 22 May 2011 - 08:56 AM
Posted 22 May 2011 - 08:57 AM
Arrington aluminum 426. Twin 67mm turbos. Nitrous outlet direct port
Paramount driveline
9.20 @ 152.42mph 1/4
5.29 @ 133 1/8 1.25 60'
Posted 22 May 2011 - 09:13 AM
I do have a trans brake but is not being used. Tim thought with all the torque we would just start breaking stuff. I agree a turbo or nitrous car would be a better application.
Tim and I are agreeing way too much lately! Something has to give
looks like good weather up in Chi town today, maybe we will see some news out of Jim & Johns cars today
Posted 22 May 2011 - 09:24 AM
Tranz brakes are cool and help with reaction times, launch and costly. My experience with a NA 472 stroker with a 727 trans and Turbo-Action valvebody with the tranz brake and also a 5400 RPM Turbo action converter. The MSD is connected to a two step that plugs to the valvebody that causes a solenoid to lock the tran between first and reverse. A two step can have a selector that allows you to select launch rpm usually between 2000-5800 rpm or plug a two prong chip into the MSD for desired launch. Once you're staged hold the brake and push the button for the tranz brake let off the brake. Push the gas peddle to the floor and the car will rev to the desired RPM. The MSD will kick spark in and out to the desire launch rpm. Sometimes it will distract the other driver. Car sounds like it may blow. When you let the button go hold on because you'll come out of the hole like a rocket. Strongly recommend a neck brace. It is a violent launch and you may brake your weakest part. The key is to shock the suspension and tires into hooking. I launched my 472 at 5000 rpm. 60 ft was 1.47 to 1.50 What’s nice is your reaction time get better with practice. I hope this helps. I'm not sure how this would work on our computer driven cars or NAG1. GSO probably knows that answer.I do have a trans brake but is not being used. Tim thought with all the torque we would just start breaking stuff. I agree a turbo or nitrous car would be a better application.
Iron6
Posted 22 May 2011 - 09:32 AM
Going to be hot and windy, but we should see something, hope they get a few passes in before the afternoon rain showers, pretty chilly in Philly this morning and it's a very light misty fog/rain here.
Tout
Posted 22 May 2011 - 11:54 AM
Posted 22 May 2011 - 01:01 PM
1. Our trans are computer controlled. This isnt a 727 or 400. The TCM is very tricky. Hence the reason you cant modify it while tuning. And the ECU doesnt seem to like the MSD rev limiters. But it can be done, just takes time and patience to make it work. So its not just buying a valve body and you are done. We arent dealing with 70s model trans. And I will double check this, but I think it is impossible with the NAG to hold 1st gear and reverse at the same time.
2. 1000+ lbs! Its not the same. You cant talk about what you can do with an old model car. Shocking a drivetrain at 3200lbs compared to 4200+ lbs is nothing alike
3. Tire sizes. Now you can covert to 15" rims and use the sidewalls to absorb the shock but 17" tires dont give you the give. So you will either grab and break parts or break traction
And Ive pulled a 1.46 60 leaving at just 1500rpm
