Making Cooling Fan Run When Car Is Off
11 replies to this topic
Justin14
Justin14
  • 30 posts
Hey guys I got a 2014 challenger rt. I'd like to find a way to make the cooling fans come on while my car is off while in the staging lanes at the track. If any of you know of a kit out there or have done it I'd really appreciate the guidance. I can't believe how horrendous the heat soak is on these cars. I can watch my track times increase as the engine gets hotter and hotter. Thanks for the help.
2014 challenger rt classic. 6speed. Mods- 6.4 SRT-8 392 Engine swap, Comp 274vvt cam, Speed Logix 392 cold air intake, billet tech fender mount catch can, Kooks 1 7/8 long tube headers, Kooks Catless mid pipes, pypes violator cat back, ported 85mm throttle body, Cmr tuned by Mike @ OST Dyno.
Hemi31
Hemi31
    BFNY Performance
  • 4,515 posts
Easiest way is to remove the fan relay and put a jumper in. There are many ways to build a system to do it off a switch as well. I bridge into the fan hot lead and build a fused circuit through a separate relay to a switch on the dash.
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Justin14
Justin14
  • 30 posts
Awesome. I saw something on lx forums that a guy sells a setup. I tried pm'ing him and never got a response. Looks like I'll just make a switch up.
Fastrt09
Fastrt09
  • 543 posts
You can buy a aeroforce gauge it has control feature built in it amongst other things
9 psi Maggie
Snow Performance, water meth kit
BCR Coilovers
LMI cai
JBA headers
Flowmaster American Thunder
85mm throttle body
PB of [email protected]
Paramount stage 2 valve body
Tuned by Hemituner
  • 9,287 posts
I disconnect the fan connector and use a dedicated battery.  Not great for the lanes, but that fan will drain a battery in a hurry.
  • 8,079 posts
You need a better battery!!! I have much better luck running stuff from the AGM than the stocker. OEM batteries REALLY suck!!!
I have one of the units from PLCman on LX, but haven't installed it yet.
I have my doubts as to how much difference running the fan makes without the water circulating. I rather just use my fan on the generator, though at the mile, it's hours between runs so not a huge deal.
Justin14
Justin14
  • 30 posts
Just looked that up, that's seems pretty awesome. I may have to jump on it.
Yea the fan mod from Plc is the one I wanted to do originally but he hasn't responded back at all about of it will work on a '14 at all. I agree the only fluid that's going to get cooled is what's in the radiator, but something has to be better than nothing at all. I was shocked how severely heat soak affects this car even with my custom tune and a 180deg thermostat.
  • 9,287 posts
I run the intercooler pump wtith the fan on by jumping the relay.  I'm sure it helps.
G Funk
G Funk
  • 316 posts
Maybe you should look into snow/meth injection instead of just running a fan on the radiator?
2013 R/T Blacktop - Cammed 392 VVT w/ forged slugs and 6.1 intake manifold, 180t, Hemituner performance TCM and bolt-ons.
Tooned by HEMITUNER (AJ)
Gotanks0407
Gotanks0407
    Tech Douche
  • Administrators
  • 2,137 posts
I did this with mine. I just unplugged the fan and cut off the plug on the fans and just ran a ground lead to a near ground and ran a positive wire to a switch I installed into dash, and put a fuse between the switch and the positive end of the battery. Should be pretty easy to run.
Although this will not do you much good unless your water pump is running. I used it to cool the water in my water to air intercooler setup. It wont do you any good on the regular factory water cooling since the water isn't getting any moment while the car is off.
Depending on the fan, the factory battery should also last you a little while its running. I used it at the track while drag racing frequently. Usually 15-30 minutes. but i had gotten quite a bit more time out of it when i left it on by accident.....
I am also going to suggest this fan upgrade if you ware worried about It cooling. This aftermarket direct replacement will add a huge amount of airflow to your cooling setup.
http://www.jegs.com/...20-039/10002/-1
Surfer1420
Surfer1420
    Just another Orange Challenger
  • 555 posts
I use the pic mod with a remote on my car. It does only cool the water in the radiator but circulates the next time you start the car.
PWR Stroker, RPS twin disc carbon-carbon Clutch,Quick Time Scatter Shield,  90mm TB, Techo CAI, Kooks Long Tubes, No Cats, 3" Magnaflow Competion Cat-back modified for G-force 9", Custom built Centerline Wheels, SLP line lock, "Joel Van" Radiator, Santhuff Drag Shocks, Solid Cradle Bushings,GForce 9" with 3.70 gear ratio.
Lashlarue
Lashlarue
  • 12 posts
Engine off . Ignition on .Defroster on . Fan switch on . Cools water in radiator to whatever you set fan temps.. Never had heat soak in over 100 passes. My car very consistent whether my passes are 5 minutes apart or 30 minutes apart .
