What kid of power are you guys/gals seeing? And what is your set up?
Thanks
Thanks
509 whp, 507 wtq. '13 stock 5.7, long tubes, no cats, D1SC 65 lb/hr injectors, API comp fuel pump. 8-9 psi
I'll find out what the 370 with the F1D is as soon as I get the boost where I want it.
-Tim
'13 R/T
(new) F-1D / 370 Stroker with way too much fucking boost!
Thanks
loaded question!
Max horsepower will vary from dyno to dyno and I have been amazed as to how much the variation is.
Most of the boosted VVT 5.7's I have done are nearly identical to Tim's setup listed above.
With nearly identical boost, fueling and timing:
On my dyno it will make 490-520
In shops I've remote or onsite tuned the exact same combo
North Carolina 600.
Utah 650.
Alabama 475.
Winnepeg 450.
This is assuming stock internals.
We did have one forum members stock internaled 5.7 here for a tune, we put a smaller pulley on, made 13psi and I believe 586whp.
Diablosport CMR Dealer
Screaming deals on Trinity's, Trinity's with wideband, Trinity w/tune discount.
www.OSTdyno.com
Email: [email protected]
I should have been more clear.. Built 5.7s. .. And I realize dynos vary Ive done so many stock 5.7s I can t even count.. ![]()
Usually we don't take the stock 5.7s over 8 psi/500 rwhp Well that is what shows on our dyno But the same cars will run 11's so I figure its pretty accurate..
Scott, sorry if my response sounded crass and I know you know dyno's vary.
I just want folks who read these posts to realize that as well. I'm sure you've experienced customers that say - "on the dyno down the road my car made xxxwhp" and you know darn well that it wont make that power on your dyno.
As you stated - what the car runs at the strip (or on the salt or in the mile) is all that really matters.
Sometimes I wish the dyno outputted torque and HP readings in lollipops and unicorns (unicorns being more than lollipops) and it only showed if I was doing better or worse.
The last few forged 5.7 VVT tunes I did in the 14psi range made just shy of 600whp on a nearby Mustang dyno (MD1100DE)
www.OSTdyno.com
My built 370 from inertia motor sports did right at 600 RWHP on pump gas, 760 on c16.
Procharger F1A @ 14lbs
Fore fuel system with return
Tuned by Josh @ HHP
Have yet to get it to the track - transmission issues. But close!
550 RWHP.
Magnuson 8lbs (street) 10lbs (track)
PWR Blower cam
85mm BBK TB
Mild tune by Mike @ OST
11.55 in the quarter.
530 rwhp 458 trq
loaded question!
North Carolina 600.
Utah 650.
Alabama 475.
Winnepeg 450.
Not to hijack but will the experience be any different running a Vortech as opposed to a procharger?
What about with a 392 VVT cam?
I also have a 392 pump, and and CPR fuel rails to go with.
160rwhp gain on C16?? I need to switch fuels!My built 370 from inertia motor sports did right at 600 RWHP on pump gas, 760 on c16.
Tuned by Josh @ HHP
Its all good.. And if I had a fucking dime everytime I heard that^^^ I would be typing from my own private island in south pacific somewhere.![]()
550 RWHP.
PWR Blower cam
85mm BBK TB
9 psi Maggie
Snow Performance, water meth kit
BCR Coilovers
LMI cai
JBA headers
Flowmaster American Thunder
85mm throttle body
PB of [email protected]
Paramount stage 2 valve body
Tuned by Hemituner
What was you mph in the quarter?
119 mph
530 rwhp 458 trq
Is anyone making big power with the 5.7vvt? Was looking at a 370 stroker, but I want to see 850+ to the wheels on the nitrous hit 400 shot. Im thinking I might need a bigger motor to reach my goal.
2011 RT Max **New 426 with DP Nitrous. Best NA pass so far 11.5. Nitrous passes to come in 2016.
(5.7 with boltons 11.44 @ 116 on 150 shot of Nitrous. Best 60 Ft 1.479. Best NA pass 12.40 @ 108)
Check out my car page on Facebook! Search NOSRT or follow the link: http://www.facebook.com/nosrt11
Didn't Mike have 950whp with a 370? https://www.facebook...type=3&theater
-Tim
'13 R/T
... 400 shot. Im thinking I might need a bigger motor to reach my goal.
Lets start here ^^^ .... DAYUM!..You ready for all that?? Boosted AND a 400 shot?? Time to panic.
PWR Forged 6.1 block -V7 YSI (18psi)- Modern Muscle ported intake manifold - Indy Heads - Modern Muscle custom cam - TTI Longtube(catless) - Paramount TC/Transmission- 3.06 Getrag-325/45/17M&H
Built 5.7 short block
stock heads
stock cam
D-1
613 /599 tq on 93 13 psi
650 RWHP/680 tq @ 5000 rpms on E85 Ran out of pump
Oh well back to the drawing board.
