6-speed Transmission Upgrades
25 replies to this topic
70challengerrt440
70challengerrt440
  • 308 posts
A few pics of my rebuild...
This last pic shows where the oil will spray from the oil pump discharge
BAYBANDIT
BAYBANDIT
  • 306 posts
nice subscribed
*ninja*
554187 290859464380836 1322499472 N
El Diablo
El Diablo
  • 612 posts
So exactly what upgrades are being done to the trans ?
TA340
TA340
    Carbon Fiber Boy
  • 2,010 posts
I have the same question Kenny. When I changed gears in mine I was only able to upgrade syncro's and switched over to the CTSV gear set. Not sure those gears are any better than stock but the CTSV puts out way more than a stock 6.1
Should be an interesting build here.
My Rides
2013 GC SRT8 The daily ride
Craig
  • 7,033 posts
looks like gt500 gears.... but hard o tell.
El Diablo
El Diablo
  • 612 posts
So has anyone came out with a better input shaft ? That seemed to be a major weak link from what I recall.
70challengerrt440
70challengerrt440
  • 308 posts
Hey guys it's a 6060. I cryoed the gears and shafts, carbon synchros 1-4, bronze shift fork pads, Drilled case for oil pump, AMP shift finger cup.
  • 7,033 posts
yes... but its still in testing
El Diablo
El Diablo
  • 612 posts
Well then why not put some out for more testing ? lol
  • 7,033 posts
lol.... not as easy as it seems.
so far this one has held up... only problem is it requires a different spline on the clutch discs and a .780" pilot bearing bore.
70challengerrt440
70challengerrt440
  • 308 posts
What power level are you testing at?
Didn't Sam twist his input shaft at 900 lbs? And he had a cryoed tranny.
  • 7,033 posts
im above that........
  • 13,086 posts
subbed to see how this goes...I'm not a trans guy, I leave that one to the experts and just R&R
70challengerrt440
70challengerrt440
  • 308 posts
Nice... did you design and fabricate the input shaft?
El Diablo
El Diablo
  • 612 posts
Twice if memory serves me correct.
70challengerrt440
70challengerrt440
  • 308 posts
Yes I think that is right.
Blue Blur
Blue Blur
  • 242 posts
Are you rerouting the pump in the TR6060 or going to run an external electric pump? I have been kicking around putting a pump and cooler on mine but wonder at what point did a Viper need one?
70challengerrt440
70challengerrt440
  • 308 posts
I am using the rear drain plug as supply and going through a small cooler spraying on the input shaft gear.
I don't know about the viper but the mustang and camaro have an internal pump.
brucer41
brucer41
  • 188 posts
Very interesting choice of routing oil cooler. What kind of pump are you going to use?
2009 Challenger SRT8 (Hemi Orange Pearl)
Modern Muscle 426 Hemi Stroker Short Block
K1 Technology Hemi Forged Crank 4.080" Stroke
K1 Technology Hemi H-Beam Billet Rods 6.125"
Wiseco Hemi Pistons 4.080" Bore
Arrington Performance Hemi Roller Rockers
Arrington Performance Hemi 90mm Billet Throttle Body
Modern Muscle Custom Stroker Camshaft (231/239 .581/.587 (113+2)
Patriot Performance .600" Lift Hemi Valve Spring Kit
Hemi TVS 2300 - Black Finish w/90mm Inlet
Kooks 1 7/8" x 3" Long Tube Headers
Kooks Catted Midpipes 3" x 2 3/4"
Magnaflow Stainless Street Exhaust System (MAG16510)
RPM Level VI T-6060 Transmission
RXT Street Twin Disc Clutch Kit
DSS Level 4 1000HP Direct Fit Axles
70challengerrt440
70challengerrt440
  • 308 posts
I was thinking of this. Its $179 and has ballbearings on the shaft. 1-2 gallons a min up to 50 psi.
Mocal Differential Cooler Pump MOC-17522HT
Taking the oil from the drain is best since it's the lowest point in the tranny. And didn't think this up, I heard other aftermarket companies were doing it. I will have it on a relay. I might even have my nitrous programmer turn it on when it sees wot.
The dodge 6060 doesn't have a tranny pump. Although I heard a rumor the Helcat does? 70
