Bell Housing Bolts To Block Metric????
9 replies to this topic
turbofreek
turbofreek
  • 813 posts
Im wondering if the bolts that hold the trans to the block are metric or standard thread???
I am batshit crazy and this was sent out from the asylums office use only computer in dos.<p>
Btp 2332
Btp 2332
  • 56 posts
I think the top 4 are 3/8 16 the rest are metric
2012 Dodge Challenger R/T, 3800 fti, JBA long tubes, 3.92's  [email protected]
Dads 2012 Dodge Challenger R/T 392, Procharged 10.42 @137
muzza61
muzza61
    Chicks Dig Me
  • 2,399 posts
I remember there being a mix.  Makes a ton of sense.....or is it tonne of sense?
- Murray -
White, with black stripes.
Modification Video:
El Diablo
El Diablo
  • 1,315 posts
Yep the block is 3/8-16 and the lower bell housing to trans are metric.
turbofreek
turbofreek
  • 813 posts
Ive got a glide so i dont have those bottom bolt issues as the big trans you guys have. Ill be able to use regular bolts. I was just worried about the top 4 bolts. You guys are the best. Thanks
Cam
Cam
  • 1,201 posts
You just gonna support your glide off those 4 bolts?. Did you happen to see the support I built for lowlife s build. I used the lower bell housing cover off a truck, then machined the mount boss locations and welded in the new mounts, worked like a champ. I wouldn't just trust the stock 4 bolt mount at that level of horse powa
Hemi31
Hemi31
    BFNY Performance
  • 4,441 posts
Actually there should be 6 bolts. Don't forget the two that go from the block to the trans. They will still be there with the aftermarket bell housing.
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Cam
Cam
  • 1,201 posts
Fuck thats right Soooooo like I's was a saying :P
novawagonmaster
novawagonmaster
  • 2,974 posts
The saying is true about Cam forgetting more about Gen III Hemis than I will ever know. lol
turbofreek
turbofreek
  • 813 posts
Also has me a mid plate to mount the bottom one to as well. lol
