468 Is Running,
119 replies to this topic
OsO
OsO
  • 889 posts
Multiple issues
1. I apparently panic and give up like a bitch these days at the first sign of trouble.
2. Way to much vacuum at one spot causing the catch can to fill rapidly and in turn the intake causing a never ending stream of smoke.
3. if i would of spent a few minutes to diagnose the issue instead of hanging up my hat and bitching i would of found it.
Time to add a few more fittings an lines
I will say it so no one else has to
DUMB ASS!!
no1special its your ass race back on . That shit done yet!
Erik thanks for the phone call.
I Should Of Built A Chevy.
Big Bear 468
10.7@123
Motor only
monty1269
monty1269
  • 2,597 posts
Now pull the tampon, and run that mufucker out the back door! Drive that sumbiotch like it owes you money.
PWR Forged 6.1 block -V7 YSI (18psi)- Modern Muscle ported intake manifold - Indy Heads - Modern Muscle custom cam - TTI Longtube(catless) - Paramount TC/Transmission- 3.06 Getrag-325/45/17M&H
Blue Blur
Blue Blur
  • 767 posts
I see your new avatar LMFAO! I left the front sender plug out of my block on first fire, you don't even want to know the shit that went through my head when
#1 I had no oil pressure
#2 the Exxon Valdez forming under oil pan....
Luckily I was only cranking it without fuel and spark.....
  • 1,885 posts
lol... Love the avatar.
10.93 @ 125.6
no1special
no1special
  • 918 posts
Multiple issues
DUMB ASS!!
Bad ass man!!! It's on for sure!!!! Very happy to hear this news
<p>462 aluminum blocked motor ,thitek heads, hogan intake, ost spec'd pro torque 4200 converter, shr war Viking from ost, paramount 8.8 rear 4.10 gears and tuning by ost,custom tcm by ost dyno, nitrous outlet direct port
OsO
OsO
  • 889 posts
I went and beat on it, a bit more than AJ wanted I ended up having to pull vacuum completely off the cc to stop oil build up in the catch can but with more miles it was taking longer and longer to fill up the catch can ..
I know AJ has doubts about the engine due to the amount of oil its pulling but i will only pull it if someone wants to buy it or if its in pieces its my last Hemi rodeo .
So far its impressive for something about to go boom on pump gas and oil.
Big Bear 468
10.7@123
Motor only
HEMI2NV
HEMI2NV
    boom goes the dynamite
  • 2,730 posts
can't say i blame with the shit you have dealt with
that Erik is a good guy
Qa69c1Z.png?2
2010 6.1 B5 auto Challenger
BFNY Performance
HEMITUNER Performance
Stock 12.94 @ 108
SC'd 11.52 @ 120
  • 9,408 posts
Multiple issues
OsO
OsO
  • 889 posts
Just a qick clip from both ends
Big Bear 468
10.7@123
Motor only
us1champ
us1champ
  • 822 posts
for what it its worth it sounds fantastic
no1special
no1special
  • 918 posts
Damn that thing sounds evil!!!
OsO
OsO
  • 889 posts
Its fun yesterday I had an HPD officer in the lane next to me tell me to "mash it!" when you leave . I said no wasn't ready we are still tuning but really i smelt a rat lol.
I have some parts coming that should hinder the amount of oil i am pulling out of the engine and allow me to keep a vacuum on the system. If it works i will post up if it doesn't forget i posted anything
Big Bear 468
10.7@123
Motor only
Cam
Cam
  • 1,478 posts
That thing sounds sweat as hell!. You could expedite sealing the rings by running under high vacuum. Do lots of high rpm engine breaking, take it easy getting up there with minimum load, but let the engine work slowing down the car. Or a electric vacuum pump temped in for a thousand miles or so. Also what oil you breaking it in with?
OsO
OsO
  • 889 posts
Thank you, Its quiet up front barely an injector tick and not over welling on the exhaust real quiet inside except for the fuel pumps.
That is about all the driving i have been doing  i have the vac line connected currently to the oil filler  just to keep it from spewing oil on the engine. The oil fill is capped with an open filter so the vacuum is not creating much of a vac  but still picking up lots of oil in a short time.
I have a small one here for not sure it would pull enough vac to make a difference.
RP break in, not the heaviest stuff but i didn't  get a fraction of this oil build up even on the boosted aluminum 440.
Big Bear 468
10.7@123
Motor only
Blue Blur
Blue Blur
  • 767 posts
Thing sounds fuckin possessed, can I ask what is your idle rpm?
OsO
OsO
  • 889 posts
Right now its holding around 1000-1100
Big Bear 468
10.7@123
Motor only
  • 9,408 posts
I just watched the idle video from the rear of the car... man, that thing sounds really nice.
romp-a-romp-a-romp it just never gets old.
OsO
OsO
  • 889 posts
Last mod
Big Bear 468
10.7@123
Motor only
Cam
Cam
  • 1,478 posts
Wtf, I was waiting for you to either lite them off or light her up with five gallons n a match. Damn it man we need some smoke and not the kind from the tail pipe.
:P
OsO
OsO
  • 889 posts
 lol, its my how rough is my idle indicator. When the car gets warm she can touch her nose to the dashboard.
 We are still working on tune but soon though..
Big Bear 468
10.7@123
Motor only
