How To Pick The Blower Size Pulley
5 replies to this topic
us1champ
us1champ
  • 706 posts
I am going to 12lbs.. i will have a 5% pulley on the bottom
any idea how to figure the pulley size?
i am 8lbs right now with stock pulley and upper i believe is 3.2
Hemi31
Hemi31
    BFNY Performance
  • 4,441 posts
2.75.....I usually see 2 psi per 1/4 inch with a 5% OD.
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
us1champ
us1champ
  • 706 posts
Thanks erik
HighHorseman
HighHorseman
  • 139 posts
What kind of blower are we talking about and on what combo? In this range I usually use the 1psi per 1/10th of an inch method for a ballpark number and add 1psi for every 5ish % OD you add to the crank. Conservatively a 2.9 upper would be my first pulley to try out without knowing anything about what the build is.
us1champ
us1champ
  • 706 posts
Is going to be a stock block 6.1 would drop in Pistons and rods in stock compression 5% overdrive pulley Magnuson supercharger
Currently I'm a stock motor right now with the Magnuson and 8 pounds of boost on the stock crank pulley and I believe the uppers 3.2
Hemi31
Hemi31
    BFNY Performance
  • 4,441 posts
2.75 just did this combo
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
