Tcm Tuning For Your Nag Equiped Lx/lc/ld/wk, Prices And Services
32 replies to this topic
Hemituner
Hemituner
  • 1,067 posts
As many of you know since starting Hemituner Performance last year one of the services I have been offering is custom TCM calibration. Over this past year at private rentals, mile events, and all the MSHS series events we were really able to put it to the test. We are happy to say that all the hard work paid off and we are truly ready to offer this service mainstream. ALL of our TCM programming is custom for your application so we recommend a consultation by phone or email so we can suit your preference's. For flexibility we offer several options to suit your needs. ALL TCM units are PLUG AND PLAY with properly programmed with your vehicle Vin number , as well as all correct gear ratios out of the box. We do not sell USED cores. Many used cores are not configured properly or often times lay outside in wrecked vehicles for long periods of time. A bad core could easily ruin your $5000 dollar transmission in just a few miles. If you do have a used core that you feel you can count on we can manually reset and reconfigure it for your application at no additional charge with your programming. We are also working on Phase 2 of development in a partnership with Z-autotech. This option will allow the end user control of shift points, firmness, and gear ratio programming with an easy PC based interface that requires no additional hardware. These units should be Available Early Spring.
TCM Adjustments available include but are not limited to
1) Part Throttle and Wide open Throttle shift points
2) Sport mode customizations
3) Auto upshift Enable/Disable
4) Transfer case Ratio adjustments for aftermarket units
5) Torque converter lockup and unlock adjustment
6) Torque management Mapping
7) Limp in limits
TCM Programming. ALL of our TCM services other than the bricked repair include UNLIMITED revisions in conjunction with our no charge support at events we attend.
1) Send in your TCM $350 with Standard return shipping included.
2) Supply a Brand New TCM $450 with Standard return shipping included
3) Supply a New TCM as well as program your current TCM $585 with Standard return shipping included
4) Bricked TCM repair services $150 with Standard return shipping included
5) SUPER TCM with end user controlled adjustment, $TBA
6) Used TCM Transfer Licensing -Purchase a Hemituner Performance TCM from another client? We will reset and Re-Vin to your vehicle, unlimited revisions $250
OUR TCM PROGRAMS ARE VALIDATED IN THE FIELD BELOW ARE SOME OF OUR BRAND NEW UNITS READY FOR FINAL PROGRAMMING AND SHIPMENT
PROVEN IN THE REAL WORLD ALL MOTOR RECORD 9.49 143
NAG CHARGER 9.0'S
https://www.facebook.com/207460799268060/videos/1182939995053464/
5200LB JSRT 8 SEC PASS
https://www.facebook.com/207460799268060/videos/1185399288140868/
100 Dale Street
Westbabylon NY.11704
516-603-9276
08 Dodge Challenger Procharged 8.71 159 Under Construction
06 Dodge Charger Arrington IRON 440 V2.0 with 92mm TB, Paramount Trans and 8.8, DSS Custom Axles, Pro Torque Billet Stator Converter, Arrington CAI, American Racing 3 inch Cat Back, American Racing 2 Inch Headers
ALL MOTOR [email protected]
TWO TIME MSHS STROKER CHAMPION 2011 2012
Renfrick1
Renfrick1
    Study hard in school and you will be successful Chase
  • 6,346 posts
Hum. We will talk more about this at the next event
But first I must consult my tuner
BuckeyeGuy
BuckeyeGuy
    Pedal faster, dammit!
  • 3,049 posts
Not only the examples AJ provided above, but my Magnum's 10.55 NA with 4:56 gears prior to converting to a TH400 would have never happened without one of AJ's custom programmed TCMs.  They are the real deal!
9.93@135mph w/200 shot       10.55@128mph NA,        6.0L/366cid
2013 & 2014 MSHS SuperStock and 2014 MSHS Index Season Co-Champion
2015 MSHS Bracket Class and Modified Class Season Champion
Spec'd and tuned by Hemituner, Paramount 8.8, DriveShaftShop, Nitrous Outlet
Arrington , Precision Shaft Technologies, TCE, GTP Porting, Rossler, Pro Torque, Kooks, Legmaker,  M/T, Corn fueled!
chris1992
chris1992
    CF3 Index Winner
  • 993 posts
Nice to see what you can tinker with! The part throttle shift points has me interested, as my MTCM seems to shift as early as possible during part throttle, requiring me to use autostick 99% of the time.
2009 Challenger R/T
PB: [email protected]
Hemituner
Hemituner
  • 1,067 posts
We can fix it for sure. I have spent a fair amount of time working on that for one of my vehicle builders. It makes all the difference.
Thanks
AJ
100 Dale Street
516-603-9276
FlyByU
FlyByU
  • 3,280 posts
There really is no substitute, Hemituner Performance isn't run of the mill, it's the best in the business.
El Diablo
El Diablo
  • 1,854 posts
Now that you have everything to make a Nag1 work as it should, how about getting someone to make some decent parts for those of us with 6 spd transmissions.
Renfrick1
Renfrick1
  • 6,346 posts
Can you do this at the track or do we have to send it In ?
Hemituner
Hemituner
  • 1,067 posts
We can provide programming at the track or if you send it in. Or you could use it as an excuse to stop buy and get a free lunch out of it!
Thanks
AJ
100 Dale Street
516-603-9276
Hemi57
Hemi57
  • 4,637 posts
Looks like the burrito eaters now have alternative to Z Automotive. AJ FTW
2010 Stone White R/T
Hemituner
Hemituner
  • 1,067 posts
If we could make a damn case that wouldn't split i would do it!!\
Hope you are doing well Kenny!
AJ
Dan thank you so much. You were my Very first client at the dealer when I came on the scene and have stuck by us 100%. Can't thank you enough!
AJ
100 Dale Street
516-603-9276
Renfrick1
Renfrick1
  • 6,346 posts
Well I do have to get my Gauges installed. Free lunch sounds good too. Ill come by when the weather warms up some
chris1992
chris1992
    CF3 Index Winner
  • 993 posts
Thanks
AJ
Good to know! On a college budget, $350 is a hard pill for me to swallow at the moment, but sometime after CF7 I should be able to swallow it lol
2009 Challenger R/T
  • 9,635 posts
Are you about to graduate already? How time has flown!!
chris1992
chris1992
    CF3 Index Winner
  • 993 posts
I wish! I was suppose to graduate in the spring, but due to my fluids class being canceled last summer, I wasn't able to take senior design this year..
Come May, I will have all of my classes done, but I'll have to go back for senior design in the Fall (our senior design last 3 quarters at 1hr/quarter). It sucks, but with my free time I should be able to find a decent co-op/internship for the year.
2009 Challenger R/T
sharkcohen
sharkcohen
    Captain Hindsight
  • 3,097 posts
AJ's TCM was a huge improvement on the drivability of my car. Best mod to date after the blower install. This is the real deal!
Hemituner
Hemituner
  • 1,067 posts
Thank you David, It will be even better with the latest round of mods. Your car was scared when we opened the door today and it saw snow on the ground , It calmed down when we promised we wouldn't put it outside lol.
Thanks
AJ
100 Dale Street
516-603-9276
sharkcohen
sharkcohen
    Captain Hindsight
  • 3,097 posts
Thanks
AJ
lol!!!
chief455
chief455
  • 16 posts
my TCM is packed to ship = can't wait!
AJ was easy to deal with via email, and confident I will be happy! American technology FTW!
2013 Charger Daytona R/T Super Track Pack
ChuckECM
ChuckECM
  • 44 posts
Hey AJ,
Does this make the Autoshifts quicker? Also, I have a KB 2.8, Ported and polished heads new cam so I'm having a problem when I launch. A lot of time it slams hard into 2nd gear and I go into limp mode. Quite embarrassing. Can you help with that? Should I decrease my shift point from 1st to second? Tim from MPH has it set to shift in all gears at wot at 6,600. I also have the ZAutotech. It speeds up the Autoshifts a bit, but not fast enough. Also a os given LSD, so it's not the peg leg, if that make a difference.
Thanks,
Chuck
