2016 Scatpack Break In Period?
Posted 12 March 2016 - 10:16 PM
Posted 12 March 2016 - 11:08 PM
2010 Stone White R/T
Posted 13 March 2016 - 07:38 AM
Any break in period with the brakes too. I know some companies have you do some hard stops....no hard stops...etc...so they don't make any noise. Once again I know I sounds like I'm gonna beat the piss out of it haha, which I never will and I always take great care of my cars I'm just new to the "brand" new stuff.
Posted 13 March 2016 - 08:40 AM
I swapped out my std brake rotors on my R/T to the larger dimpled/slotted SRT fronts (14") and Daytona rears (14") and had to "bed the brakes"... that is 5 or 6 panic stops from 60 mph to 5 mph then park and let cool. This really gets the brakes hot, you will smell them, and you get a bit of pad transfer which what you want. The early R/T's were notorious for having warped rotors. Not sure about the Scat Pack.. you may want to check the size first.
Posted 13 March 2016 - 10:04 AM
Follow the owner's manual for engine break-in. It will probably say something like drive it easy and no WOT runs for the first 500 miles.
As far as brakes, most people around here recommend standard bed-in procedure, as outlined here: https://www.zeckhaus...cPath=6446_6443
Personally, I'd change the oil after the first 500 miles, but some would say that's unnecessary.
Posted 13 March 2016 - 12:19 PM
Just don't run it at the same rpm's to long. Vary your speeds. It is good to get on it pretty hard when you reach a slite grade in the road & then back off when the road levels back off. Make sure you let the motor warm up good before you start playing. I would stay out of slow traffic & not let motor idle for long periods of time. It should be broke in pretty good around 500 miles. Don't baby the motor after that. After all it is under warranty. Anything happens to it Dodge will have to fix it.
Posted 14 March 2016 - 04:23 AM
Posted 15 March 2016 - 05:49 AM
Posted 18 March 2016 - 04:21 AM
Posted 18 March 2016 - 08:48 AM
Don't listen to Kevin as he will offer you $50 for it after you blow the engine! lmao
Posted 18 March 2016 - 04:34 PM
i think 37 miles is enough!!
Grandpa Greg
Camarofest 5 2010
Challengerfest 1 2010
Challengerfest 2 2011
Challengerfest 3 2012
ChallengerFest 4 2013
ChallengerFest 5 2014
ChallengerFest 6 2015
MSHS various
PB 0-60 4.40 Street Tires on the street Calabash 10/14
PB ET 11.608 at VMP 9/15
(new 915 VMP) Slowly getting there.
PB 60' 1.601 at VMP 9/15 (new 9/15 VMP) new pb but not by much
PB MPH 120.03 at MSHS ATCO 11/14
Posted 24 March 2016 - 07:11 PM
Posted 24 March 2016 - 07:31 PM
Then go back after 500 miles and see if it improves
Posted 24 March 2016 - 08:31 PM
Posted 24 March 2016 - 09:01 PM
