Sucking Tank Dry With Api 1500 Return System?
Posted 06 October 2016 - 01:45 PM
Normal with a dual pump return style system? Or did I lose loose some return from the right tank into the left?
The evic showed 5 left and 17 right when it happened today. All is fine when I fill the tank until right around 1/4 tank.
393 '07 Magnum
Posted 06 October 2016 - 03:29 PM
Posted 06 October 2016 - 04:14 PM
It actually cavitates the pumps when it's that low. I doubt you have it hooked up wrong.
Great, thanks. Things kind of caught be by surprise and I thought oh shit, until I put 2 and 2 together.
Dude in Cobra behind me thought flames were really cool though ...
393 '07 Magnum
Posted 06 October 2016 - 05:50 PM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 06 October 2016 - 06:41 PM
Any reason not to modify a pump for the passenger side to feed fuel back over?
2010 SRT/8 Challenger six speed 34000 miles $29000
Posted 07 October 2016 - 06:22 PM
Yeah....you need to be closer to 1/3 or more for WOT pulls. 1/4 tank is minimum.
Good stuff. Thanks
393 '07 Magnum
Posted 08 October 2016 - 10:41 AM
it does feed fuelAny reason not to modify a pump for the passenger side to feed fuel back over?
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 22 October 2016 - 11:08 PM
You ever consider having the return go to the feed basket on the driver's side? We have the return from our 1500 pump going right back into the basket and we can run at WOT with wheels up 9.8 at the drag strip with as little as 4 gallons of fuel.
MoparMax.com
Driver: Alex "The Car Girl" Rogeo
2007 MSRT8 Arrington 426|Magnuson Supercharger|Hedman 2" Long Tubes|908 hp 866 lb ft
DSS 9" rear, axles & CF driveshaft|Stange 3rd member 3.89 & spool
5000 stall |Westminster Transmission TH400||LAT OIL & ATF
Diablosport Trinity|Mickey Thompson|RPM Rollbar 8.50 Cert
9.85@136 mph - NHRA PSCA WCHRA
2012 & 2014 PSCA Street Muscle Championship Runner Up
Posted 23 October 2016 - 06:45 AM
~4 gallons is the point where the issues start with the current setup.
For the sake of pump longevity, I'll be more mindful to keep it above 1/2 tank now.
393 '07 Magnum
Posted 24 October 2016 - 12:40 PM
Mine does the same thing on my FORE return style set up. I lost a motor last year by not having enough fuel in the tank. 1/2 tank from then on.
Posted 24 October 2016 - 01:25 PM
After experiencing what happens in the situation, I can see how you could lose an engine.
So, for the sake of pump AND engine longevity, I'll be sure to keep it at 1/2 tank as well.
393 '07 Magnum
