Sept162011StockTuneSolo16Celcius4th.jpg 131.5KB
34 downloadsOn friday on the way home, I did another run just for a comparison - car was feeling strong again, but as I was getting into the power band I felt a noticeable dead spot, then power picked back up and pulled to 5600 or so. That has never, ever happened in 4th before. This is the graph.
Sept16_22011StockTuneSolo16Celcius4th.jpg 131.55KB
36 downloadsFor some reason at about 3500 RPM I got a huge amount of knock - knock ST retard was 12.5!
Again, this has never happened in 3 years with the car. I have like 50 logs of pulls and none have knock like that. Nothing was changed between the days, same gas, same road, same temp even. I took it back out last night with the wife and went to about 4k in 4th a couple of times. Once, it felt totally normal and once again there was some hesitation although not as pronounced as in the afternoon.
I'm a bit freaked out by this - but have no real idea where to start to look for causes. The only thing I'm thinking is maybe plugs? They are still original - I was going to change them this winter but maybe the time is up. There is no noticeable miss and it doesn't seem to be running rough at all though - hence the wtf?
Comments / suggestions welcome.
