whats the most we have really seen without a loud pop? I know stevewalker9 pulled 499 or so... not sure on the dyno type..
my 93 tune its now 475 /476 with a 11.2 to 11.4 afr..
if your motor popped at xxx hp with xxx afr please hop in and let us know
speedy i need to send you my pull so you can look it over....
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. This message will be removed once you have signed in.Login to Account Create an Account
Whats The Most Rwhp On Stock 5.7
Started by Plumkrazy, Mar 02 2011 09:00 PM
17 replies to this topic
Posted 02 March 2011 - 09:00 PM
Posted 02 March 2011 - 09:06 PM
Cool, just e-mail it.
If you can, go out and make a full pull in 4th gear from 2K RPM to revlimit. I'll run it through TT Dyno to compare. I have a special dash board just for that I can send you. E-mail me and I'll reply with it.
There was a buy over on CT with a Kenne Bell 5.7. I think he was in the 530RWHP or so range if memory serves. Adam at ST had tuned the car. 8lbs of boost I believe.
Posted 03 March 2011 - 03:32 PM
spankin times can get like 700rwhp out a 5.7 cant they? on a stock pump and 91 octane
Posted 03 March 2011 - 05:25 PM
man i got that easy mike.. im running 179* of timing and 7.99 lbs of boost...
actually i pulled 400 ft lbs on their dyno with my rear engine rider and their canned tune with 1/2 bottle of torco on 93 octane... and my yard still looks like crap.
Posted 03 March 2011 - 05:34 PM
Posted 03 March 2011 - 06:31 PM
You sound like you doubt that George?http://challengerclick.com/public/style_emoticons/default/laugh.gif according to the last KB guy from ST, the torco alone was worth 36 extra hp with no other changes.
http://www.challenge...co-magic-49063/
Posted 03 March 2011 - 06:57 PM
The KB guy done by Spankin' Time is the highest I've seen.
Dan - question. You ran your street tune and 93 Oct to hit the 118mph out the back of the quarter in Florida? Inquiring minds want to know
Posted 03 March 2011 - 07:37 PM
ill let you know when i find out PK
Posted 03 March 2011 - 07:55 PM
no..ms 109 tune... i just said my street tune numbers..
car was @ 503/495 @ 60* ambient
12.2 12.4 afr
12.2 12.4 afr
Posted 03 March 2011 - 07:59 PM
Plumb I drumed 491rwhp @ 5400 6lbs on a Dyno Jet. Last Saturday trapped 117 in tulsa. I could not break into 11s. Track asphalt temp was 51deg. Sucked.
I am worried about the Mexican Hat Dance at any moment. Fuuuuuck
Posted 03 March 2011 - 08:04 PM
mine were on a mustang dyno.. I really want to put it on another dyno to compare with a known tune hp car.. I see dyno's as a tool unless were using the same tool its hard to really compare... i did hit 8lbs well 7.8
Posted 03 March 2011 - 08:07 PM
Figured you had something a bit spicier than the street tune. Good on you, man.
Posted 03 March 2011 - 08:18 PM
cooler weather im looking at 11.50
we were @ a 1500 area d/a at the time of the run.. i think mike had it 14xx when we were cooling the car down
Posted 03 March 2011 - 08:29 PM
DA hovered right under 2k
Posted 03 March 2011 - 08:32 PM
Posted 03 March 2011 - 08:41 PM
I'd love to see you hit 11.5, Dan. Will be that much sweeter taking it back
Posted 04 March 2011 - 01:59 PM
Dan, sent you some info via e-mail last night.
Add the info I mentioned and I can get you a very good comparo on your numbers.
Posted 04 March 2011 - 10:30 PM
