Nag1 Cooler Line Flow Question
No replies to this topic
dogonmut
dogonmut
  • 441 posts
I want to make sure my cooler plumbing is going the correct way, with gravity, so...
On a 6.1 equipped vehicle with a NAG1 (2010 Challenger), which line is the feed to the cooler and which is the return?
I'll crawl under Saturday to look when I'm plumbing, it may be obvious, but a for sure answer would be helpful.
Thanks.
-Scott
2010 SE
6.1L motor swap
Magnacharger
90MM throttle body
Custom CIA
Solo high flow CATs
Pypes exhaust
SHR Viking NAG1
Pro Torq 3K stall converter
ATI flex plate
SR/T8 suspension
3.06:1 Getrag rear end
Front Baer Pro-Plus brakes
Rear Brembo brakes
Mickey Thompson Street Comp tires for the street/track
Some people follow Jesus. Some people follow Buddha. I just try not to be a cunt.
