I'm looking for an Accessory switched 12v wire to hardwire my Innovate LM-2 into. Also a ground wire. Is there anything in the area above the driver's feet? I'm sure someone has found one to wire something.
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. This message will be removed once you have signed in.Login to Account Create an Account
Looking For A Switched 12V Source In The Dash.
Started by rick s, Sep 29 2012 01:00 PM
4 replies to this topic
Posted 29 September 2012 - 01:00 PM
Rick
2009 Challenger SRT, Hemi Orange, Automatic
Kenne Bell 2.8LC Supercharger
Posted 29 September 2012 - 01:34 PM
If you pull the console, you can ground to a bolt under and behind the shifter. You'll also find plenty of wires in that area to connect to if you want to take that approach. You'll see there are a series of electrical connectors you have to unplug (lighting, lighter/plug, etc...). They're switched.
Posted 29 September 2012 - 02:18 PM
I think the accessory plug on the front of the console is switched. I added a circuit boss and used that for pretty much everything I've added.
Posted 29 September 2012 - 02:48 PM
2010 Stone White R/T
Posted 29 September 2012 - 06:05 PM
If you want to wire it and don't mind doing some work, including finding a pin that goes into the under hood fuse box, that's a good way to go. Get the weather proof one with three circuits and you'll have capacity to hook other things up. It's what I use but it takes time to run all the wiring, heat resistant loom, go through the fire wall...yada yada yada. A lot of guys just use the plug without issue....you could easily fuse that connection.
Your call.
Your call.
