Damn!!!! Electronically Controlled Procharger!!!!!!
Posted 26 October 2012 - 09:27 AM
Posted 26 October 2012 - 09:35 AM
06 MSRT8 Mods: PWR 393 stroker, w/F1A, Mondello Stage 3 heads, DSS 9" IRS. Installed by AfterHours Mopar Performance. .
Posted 26 October 2012 - 09:42 AM
Posted 26 October 2012 - 09:50 AM
Posted 26 October 2012 - 09:51 AM
Posted 26 October 2012 - 10:09 AM
Posted 26 October 2012 - 10:12 AM
Posted 26 October 2012 - 10:20 AM
11.697 [email protected] mph 4/14/12 Beech Bend Dragway
Posted 26 October 2012 - 10:28 AM
That looks cool. Hopefully it won't be plagued with belt issues.
Kind of like having a continously variable transmission. Just wait till guys want to up it to 20lbs!
Always loved that Mad Max blower.
It's the reason I have one now.
Posted 26 October 2012 - 10:34 AM
Posted 26 October 2012 - 10:39 AM
One of the inherent issues with superchargers is there isn’t an easy way to control boost; you have to pop the hood, remove the belt, and change the pulleys. People have put intake wastegates and boost controllers on superchargers, but this is typically bad for the supercharger, since it’s typically going to operate at full bore all the time. On the other side of the spectrum, large turbochargers create issues in form of turbo lag and increased under-hood heat – or smaller turbos typically taper off boost levels at higher RPM.
ProCharger has stepped up to the plate to create a product that’s undoubtedly one of the most revolutionary designs available in the aftermarket. What’s all the fuss? ProCharger calls it a programmable ratio supercharger. Think of a constant velocity transmission in a late-model vehicle that has the ability to vary gear ratios on the fly. When you take off from a start, A larger belt drive pulley with a smaller supercharger pulley will create immediate boost at low RPMs, and as the revs continue to climb, those pulley sizes begin to automatically reverse to give constant boost pressure at virtually any RPM.
The touchscreen display acts like a boost controller with four levels of boost. This technology will allow you to make more torque at a lower rpm, more horsepower at redline, and changeable on the fly for different driving conditions. There is no doubt that ProCharger’s Programmable Ratio Supercharger will be a strong contender for SEMA’s best product award.
ProCharger Debuts Programmable Ratio Supercharger, an Industry First
LENEXA, Kan. – Accessible Technologies, Inc., manufacturer of ProCharger supercharger systems, is proud to introduce the industry’s first programmable ratio supercharger, the i-1® ProCharger. Featuring an intelligent control system and optional touch screen display, drivers can switch between 3 factory supplied performance modes, as well as a custom mode. The patented programmable i-1® design produces immediate response, even at low engine rpm, without any turbo lag or power falloff at higher engine rpm. Check out this new product in action and see the innovative internal design via 3D animation at http://youtu.be/pPrL6ebUrDU.
This latest addition to the product line delivers the many benefits of the current ProCharger offering, while adding programmable boost and cockpit control as additional features. Designed and manufactured in the USA, i-1® ProChargers feature exclusive billet impellers and rugged gear cases. Programmable boost is delivered by a highly durable variable ratio transmission design, with a rugged dry hybrid drive. ProCharger i-1® supercharger systems will begin shipping in early 2013 for a variety of late model vehicles, including 2010-13 Camaro SS, 2011-13 5.0L Mustang GT, 2008-13 LS3 C6 Corvette, HEMI 6.1L and 5.7L Challenger/Charger/300, Ford 6.2/5.4 F-150 and GM 6.2/6.0/5.3 Truck/SUV applications.
Posted 26 October 2012 - 11:33 AM
Posted 26 October 2012 - 11:40 AM
I'd say Procharger just kicked 'em right in the dick dick...http://www.youtube.com/watch?v=pPrL6ebUrDU&feature=youtu.be
Procharger just slapped every supercharger company right across the face with this.
PWR Forged 6.1 block -Novi1500 - Modern Muscle ported intake manifold - Indy Heads - PWR cam - TTI Longtube(catless) - Paramount TC/Transmission- 3.06 Getrag-325/45/17M&H-
Posted 26 October 2012 - 12:06 PM
Posted 26 October 2012 - 12:12 PM
Posted 26 October 2012 - 12:18 PM
Posted 26 October 2012 - 12:31 PM
Posted 26 October 2012 - 12:42 PM
Posted 26 October 2012 - 12:59 PM
- James
Yea, It's Done !!! 392 Stroker Self Installed
Posted 26 October 2012 - 02:30 PM
