Installed Arrington catch can last April. I moved the wire harness that supports the IAT, Camshaft Sensor and the other sensor down below (oil something?). Bracket for the new catch can too short. Makes it real difficult to remove bucket because it is so close to the engine and hot hoses. Rerouted wires behind the coolant hose bracket. Start car and code pops up. Ironchallenger makes me a longer bracket for the puke can thus making it easier to remove bucket. Put wire harness back to where I found it. Clear code. Start car and no more cel.
Early October. Replace Maggie under warranty. Reinstall IAT under the bottom of the Maggie. Drive car a few times. Code pops up. Won't clear. Replace $12 Cam sensor on pass side of engine at the front. Code clears at idle. Take her down the street and code is back in less than 30 seconds of driving.
I am thinking I must be dealing with a wiring short somewhere. Oh joy! I am so happy now! NOT! The IAT wire was doubled up, tied with a plastic tie and stuffed in the opening just under the tub of the Maggie during the original install October 2011. Lots of heat there as well as lots of heat from the heater hose which is close to the entire harness. Stripped back all of the factory tape and inspected wires. Looks good.
Bought a Multimeter today. Don't know how to use it but this is the tool you use to find shorts. Correct? Can someone tell me how to use this thing. Is the engine supposed to run when I am using the probes or do I just have to have the ignition on. What position do I turn the dial to? What am I looking for? Volts (5, 7 or 12?) or Ohms?
I read that this cam sensor is part of the BUS harness and the VVT. If there is a short in the IAT wires, would it trip the P0013 code?
Anyone else here run into this particular CEL?
http://share.qclt.co...tem/0060015.pdf
multimeter.bmp 1.37MB
7 downloads
