5-axis CNC Ported High Velocity HEMI Throttle Body was developed to help increase
the flow of air through the stock intake manifolds of the new HEMI engines. AND IT WORKS! The stock
80mm throttle body has shown on many applications to be a restriction on these engines but with new venturi-like design, airflow through the stock throttle body has been increased allowing even
more power while being a direct bolt-on part.
High Velocity Throttle Body is opened up to 87MM, varying
throughout the inlet and with a superb design based on their 30+ years of drag and oval track racing, from
NHRA to NASCAR, this throttle body makes power without introducing any of the negative airflow
characteristics that must be tuned out. It also works great on mildly modified 5.7L and 6.4L engines.
Features:
Fully Plug and Play
Max Airflow Through OEM Throttle Body
Perfect Drivability
No Issues Requiring Tuning*
Patent Pending
*Basic tuning is recommended at WOT to compensate for the additional airflow into your engine to optimize
power.
Throttle Bodies are brand new CNC ported OEM throttle bodies.
If you would like to get your order in:
http://www.speedlogi..._p/mmhv2013.htm
Thanks!
Mikey
