15" 325 Dr
92 replies to this topic
Is anyone running one of these on a Challenger?  Even with the car on the ground it's rubbing the inner wall a little bit, I thought a heat gun might work to mold it back...
Paramount driveline
9.20 @ 152.42mph 1/4
5.29 @ 133 1/8 1.25 60'
Drp6982
Drp6982
  • 2,788 posts
im running them but on a Charger.... its a super tight fit but they dont rub on mine
Also, double check you have the correct wheel on the right side, those tires are directional and I think you have it backwards
435 BES w/ N20 Outlet Direct Port
9.22 @ 148.69mph
thanks man, i will give that a try.
Paramount driveline
srt5939
srt5939
  • 9,818 posts
it's not backwards
it's upside down
dumbass lol
8.92 at 154mph
Hemi by  Hemituner
OsO
OsO
  • 907 posts
His sig says 9s im putting mine on backwards too!!! :D
Big Bear 468
10.7@123
Motor only
Hemiwoman
Hemiwoman
  • 874 posts
Lakey, we run the 17" 325s on our car and they rubbed on the inner fenderwell also.  Ken put a couple screws in the inner fenderwell and screwed into the metal behind it and it took care of the problem.
  • 18,597 posts
That right there is winning^^^^  I'd have had the three pound hammer out but that's just my thing...
vroom vroom...
  • 7,376 posts
why must you post an american hitting a canadian!
thats Racist!
:P
Guest_Daparrothead_*
I had some slight rubbing issues with my 295's, I did the Sam method & got rid of the hump in the inner fender well first, then worked on the plastic with the heat gun and finally put a few pop rivets in it to hold it in place.
Drp6982
Drp6982
  • 2,788 posts
Im running faster 9s so I have to be right lol
9.22 @ 148.69mph
OsO
OsO
  • 907 posts
lol,  The lack of 9s must not be related to my tires then.
Big Bear 468
10.7@123
Motor only
FlyByU
FlyByU
  • 3,221 posts
Clearances are not the same in the wheel well between the LX and LC from what Ive seen.
novawagonmaster
novawagonmaster
  • 2,974 posts
What fuel fill tube?
BuckeyeGuy
BuckeyeGuy
    Pedal faster, dammit!
  • 3,016 posts
That wandering cursor in your posts freaked me out...
9.93@135mph w/200 shot       10.55@128mph NA,        6.0L/366cid
2013 & 2014 MSHS SuperStock and 2014 MSHS Index Season Co-Champion
2015 MSHS Bracket Class and Modified Class Season Champion
Spec'd and tuned by Hemituner, Paramount 8.8, DriveShaftShop, Nitrous Outlet
Arrington , Precision Shaft Technologies, TCE, GTP Porting, Rossler, Pro Torque, Kooks, Legmaker,  M/T, Corn fueled!
  • 18,838 posts
I just noticed that, wtf? lol
yeah that cursor is f'ed up dan.
just swapping the tires to the other side didnt do it. there is definitely a support behind the wheel well, i guess i'll try pushing that back some.  these things are pretty big, definitely wider than a 10.5 slick
Paramount driveline
  • 18,597 posts
thats Racist!
:P
You know me.  Pure white racist....
3lb hammer FTW, John, but get a sense of where you're rubbing (not rubbing one out...) when the car's sitting on the ground and suspension is fully loaded.  If it's simply in that spot where there's the rise in the sheet metal, 3lb hammer FTW.  I like the idea of the pop rivets for the liner.  If there's more contact then you'll likely have to look at a spacer or a different offset.
vroom vroom...
Drp6982
Drp6982
  • 2,788 posts
Sorry, I wasn't implying swapping the tires would give you clearance... I was stating that the tread is going in the wrong direction. Take a look at the picture of my car I posted above and look at the direction of the tread
9.22 @ 148.69mph
novawagonmaster
novawagonmaster
  • 2,974 posts
I think he was just test fitting (in which case it doesn't matter which side/direction).
Besides... Legmaker says they work better backwards. lol
srt5939
srt5939
  • 9,818 posts
Theres a fucken arrow on the sidewall for christ sakes
8.92 at 154mph
Hemi by  Hemituner
