Mobil 1 is perfectly good, but so are other full synthetic oils (vs semi-synthetic). Most are made with Group 3 base stocks which is the vast majority of the motor oil and then there's a small percentage of an additive package or "add-pack". Not too many companies / refiners that make Group 3 base stocks and a lot of the trade them to avoid location differentials (read: transportation) so oils aren't as varied as most seem to think. Also, less than a handful of additive companies. Now Mobil 1 is a bit different in that they use polyalphaolefins (PAO's) for the base stock. Not saying that's better, but it is derived differently. It's more a chemical based stock.
Some believe you should break in a stroker with non-synthetic but I've broken in a few without it no probs. Just change out after 500-1000 miles under varying loads.
An important question for the weight / viscosity of whatever brand you use: where do you drive the car? Temperatures for cold start are relevant...important. If you're racing the motor a lot I'd go a bit heavier viscosity than recommended. For what it's worth a thinner oil will provide better gas mileage assuming it's of reasonable quality and a heavier oil of reasonable quality should provide a bit more protection under extreme loads.
