Rear PDC, Fuel Pump Relay.pdf 227.93KB 20 downloads
Per the service manual, you want your tank to be less than 5/8 full when you open it, but the lower the better. Instead of driving around to burn gas, you might find it easier to use the fuel pump to empty the tank.
All you need is some tubing that you can attach to a fuel crossover. For instance, in the 6.4L engine, the stock crossover is 3/8" fuel line. Get some cheap 3/8" vinyl tubing and a "T" barb fitting. You can use this to tap into the crossover, emptying it into a gas can. If you've upgraded the fuel rails, you might might have some ports you can tap into, or crossovers that disconnect. If you have a lift, you could also just disconnect the fuel line from the rails at the quick disconnect and empty it straight down into a bucket.
Before you start disconnecting anything, though, you need to relieve the pressure in the fuel system. The more recently you've driven the vehicle, the more residual pressure you'll have.
1. Pull the fuel relay. It's located in the Power Distribution Center in the trunk. I've attached a PDF so you can find it easily.
2. Start the engine, or at least crank it a few times.
3. Now tap into your fuel system, and set it up so it drains into some sort of gas container.
4. Jump terminals 30 and 87 of the fuel pump relay. When you're looking into the trunk, with the fuel pump relay removed, those are the upper left and lower right terminals (or using the car's orientation, driver side front, and passenger side rear). You'll hear the fuel pump activate, and the fuel will start emptying into the can.
It takes just a few minutes to empty an entire tank this way. I always like to keep my tank nearly full, so it's hard for me to time the start of a project with an empty tank. Knowing how to empty your tank like this can save a lot of time, or at least allow you to start your project whenever you want to.
