Alot of the higher hp GM guys are pulling their MAF sensors as well and going speed density.
Joel, you know I respect you but I need to disagree - at least partially, since this is a "pet peeve" of mine (lack of MAF tuning in this platform)
I tune quite a few decent HP GM's (1000+ whp) and for the older models where the CAL can't support the higher MAF frequency you are correct - we will do as you are suggesting and switch to a 2 or 3bar OS and tune via SD.
However, on the CAL's that can support the MAF frequencies, in 100% of the cases we will swap the MAF cartridge into a larger intake tube and tune via MAF before trying to switch to SD. MAF tuning is a breeze and from a cutomer/performance modification standpoint the MAF tuning allows the customer to swap in components (exhaust, intake), raise or lower boost etc. and (in most cases) no tuning changes required. The MAF also is fantastic at adjusting for ambient temps so the need for a different tune for cold/dry air vs. hot humid air is diminished.
Two weeks ago I did a big turbo LS car that we switched from MAF to 3bar SD. It took about 3-4 revisions to get the idle/cruise tuning correct and about 7 dyno pulls/revisions (3 different boost levels with the AMS controller) to get the tune dialed in.
Monday I will be tuning a newer turbo GM truck, same HP level (1100+ whp) and this will be MAF only. I am hoping I can nail it in one idle/cruise revision and 3-4 dyno pulls.
I guess it's a moot point here....
It sure would be nice to have that option on this platform (or a blended SD/MAF) but that may never happen...
Again - no disrespect intended.
I do and will continue to look to you as a resource and a sounding board for ideas with the Gen III Hemi platform.
Diablosport CMR Dealer
Screaming deals on Trinity's, Trinity's with wideband, Trinity w/tune discount.
www.OSTdyno.com
Email: [email protected]
