Tail Pipe Backfire
25 replies to this topic
Bailman
Bailman
  • 204 posts
Have had a tailpipe backfire and read that the bad MAP Sensor is bad so I replaced MAP and it still has tailpipe backfire though the car feels better. It happens when giving it a nice amount of pedal or @WOT. It doesn't matter if I have it in 3 or 4th gear or (D)rive. What else should I look into doing/replacing to stop this?
2005 Black Chrysler 300c:
FRI/d: Decked .030 Street/Strip Heads
STU/d: SRT Max camshaft
AJ Berg Sunoco 93 Octane Tuned
STU/d 400CI Stroker on deck
Mopar408
Mopar408
    Drivetrain Tester
  • 2,639 posts
Any codes?
MOPAR408
2009 Challenger SRT8 - 6SPD
11.55@120 w/ a 1.60 60'
Hemituner
Hemituner
  • 1,067 posts
Sounds like you may have broken a valve spring. I suggest getting the valve covers off to take a look.
Hope this helps
AJ
Hemituner Performance
100 Dale Street
Westbabylon NY.11704
516-603-9276
08 Dodge Challenger Procharged 8.71 159 Under Construction
06 Dodge Charger Arrington IRON 440 V2.0 with 92mm TB, Paramount Trans and 8.8, DSS Custom Axles, Pro Torque Billet Stator Converter, Arrington CAI, American Racing 3 inch Cat Back, American Racing 2 Inch Headers
ALL MOTOR [email protected]
TWO TIME MSHS STROKER CHAMPION 2011 2012
Bailman
Bailman
  • 204 posts
 No codes. OK will do on the covers, Aj
Hemi31
Hemi31
    BFNY Performance
  • 4,611 posts
Was the any other noise? Broken or weak spring is a possibility and so is a bent pushrod.
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
  • 18,854 posts
The only time I had backfire on my car was when the #1 plugs were crushed, broken ring lands on the factory 392. Good luck finding the issue.
THE PHANTOM
THE PHANTOM
  • 41 posts
Was this a constant thing bailman. I had this happen to me twice after I got my car back on a new build.. I thought it was because it was really cold outside leading to a rich condition in the tune due to my car being tuned in the 95+ Florida heat. It did it when it was really cold in December twice one day and then another cool evening around April when I was driving it to the track. It never did it under load at the track. I have yet to put the valve covers. May get my mechanic to do so. I think also my plugs may have been gapped to much as well. I think I did a plug change after that. I haven’t had it happen since but after this post I am a little concerned on the internals. Could be nothing my car is far from stock but who knows?
Bailman
Bailman
  • 204 posts
No other noise, E. This wasn't a one time thing. Its anytime I get into it for a HWY pass or HWY Shits/Giggles WOT. No lights/codes... not even general misfire. MPG is down historically. I know we spoke about changing out springs way back when. Does someone know which springs I need for the MDS I still run? I would order some new ones if I could remember.
Thx, Dude. I'll let ya know what the outcome is/was.
Yeah, Bish. This is a reoccurring thing but now I think about it it might not be 100% of the time. Maybe coil packs or wires but the no codes has me stumped with what has been happening.
Knownman
Knownman
  • 1,857 posts
Curious about this discussion.
I get a back fire occasionally. Only time I notice is when in 2nd gear and I get off the throttle. Sometimes I hear it backfire.
I don't notice anything during Wot boost or normal?
What do you guys think?
Special Thanks to;
Hemi31
Hemi31
    BFNY Performance
  • 4,611 posts
Brian how old are the plugs?
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Knownman
Knownman
  • 1,857 posts
Erik,
Are you asking me about the plugs?.
If so they're copper 4306's with 7k or so miles.
Only happens when I get out of the gas and stay in gear and the car engine brakes.
Special Thanks to;
Bailman
Bailman
  • 204 posts
I changed them this Late Spring. What freak'n spring do I need to get and where is "the place" to get them that will allow MDS Activity and go with the parts in me Sig? <Haha> MDS Activity. My brain is shot and needs some help in recollecting.
Hemi31
Hemi31
    BFNY Performance
  • 4,611 posts
MDS has nothing to do with the springs. Its all.in the lifters. As long as the cam has lift low enough for the lifter to actuate MDS works. Since you have the FRI SS heads you have the PAC 1518 springs. Josh should be able to get them. If not call me and I will get them.
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Knownman
Knownman
  • 1,857 posts
Guess you aren't asking me
Special Thanks to;
asianANDY
asianANDY
  • 84 posts
Bailman,
I'm having this issue too...the car backfires half the time when I hold it in gear then got wot or give it a nice amount of gas. When this occurs,  feels like it hits a brick wall. The car goes limp, I remove my foot from the gas pedal and a second later...everything is back to normal. I'm going to follow this thread closely to see what solves your issue and I might try it myself.
Bailman
Bailman
  • 204 posts
Thanks for the info. Josh should be on his Honeymoon so perhaps you'd be a better vendor. Tony gonna do the work so let me know the $$$ and give me your # so I can get these ASAP. One last thing, Bro. What Iridium's should I get? B/c I cannot keep changing plugs every season which these coppers only seem to be lasting. :o
Bailman
Bailman
  • 204 posts
A update to all of the tailpipe backfire issues. It has apparently cleared up. After more days with the new MAP Sensor installed I have yet to see any of the problems I was experiencing before and just after replacement. Its a cheap and fast way of seeing if that is causing the problem. Hope this helps.
TA340
TA340
    Carbon Fiber Boy
  • 2,164 posts
Good to know it was a cheap and easy fix. Thanks for updating. It is always good to learn from others positive experiences.
My Rides
2015 Charger Hellcat (Wife's new ride) [email protected]
2013 GC SRT8 The daily ride
Craig
  • 18,854 posts
Glad you got it worked out.
1FST4DR
1FST4DR
  • 2,751 posts
Erik,
Well Im not Erik but one thing I notice is if you are boosted you are running the wrong plug.  You should be running 1 step colder   If you are not boosted then you are fine with that plug   I just didn't remember what your Mod list was..
I 'think' you would run a 2314 ngk same heat range as a 6.1  which will be one step colder.   Or a 2315 will be 2 step colder...
