Lets Talk Fuel Systems
Posted 21 August 2011 - 12:37 PM
Posted 21 August 2011 - 12:53 PM
Posted 21 August 2011 - 12:56 PM
Posted 21 August 2011 - 01:15 PM
Posted 21 August 2011 - 09:48 PM
- Tim
Posted 21 August 2011 - 09:51 PM
Posted 21 August 2011 - 11:19 PM
was trying to figure out how our system worked.
Vision Sports Art![]()
Posted 22 August 2011 - 06:53 AM
Jeff
Posted 22 August 2011 - 07:01 AM
Posted 22 August 2011 - 08:05 AM
Wiring in a boost switch would fix it also. I haven't got the parts yet Josh said he is working on it.
Posted 22 August 2011 - 09:09 AM
Posted 22 August 2011 - 09:15 AM
Posted 22 August 2011 - 09:38 AM
Posted 22 August 2011 - 09:45 AM
Posted 22 August 2011 - 09:47 AM
Posted 22 August 2011 - 10:01 AM
Posted 22 August 2011 - 10:06 AM
Yea probably not 200* but dam hot when it's getting ran through the fuel rails at a tank full every 8 minutes. That heats the shit out of it.oil has whats called viscosity, not the same as gasoline. Two different types of petroleum
fuel in your tank is also not reaching 200*
All I know is I have ran out of fuel every time I have drove the car more than a hour at a time. Pumps are still running I can hear them. The gauge says 0 psi leave the key on and you can hear the pumps start pumping fuel again then you can start it and go.
Happened at over 3/4 of a tank 1/2 tank and 1/4 tank also. I checked the tank for pressure it's not that. Thought maybe it wasn't venting properly.
I don't road trip much so it's not a huge inconvenience for me.
Posted 22 August 2011 - 10:13 AM
Posted 22 August 2011 - 10:37 AM
Yea probably not 200* but dam hot when it's getting ran through the fuel rails at a tank full every 8 minutes. That heats the shit out of it.All I know is I have ran out of fuel every time I have drove the car more than a hour at a time. Pumps are still running I can hear them. The gauge says 0 psi leave the key on and you can hear the pumps start pumping fuel again then you can start it and go.Happened at over 3/4 of a tank 1/2 tank and 1/4 tank also. I checked the tank for pressure it's not that. Thought maybe it wasn't venting properly.I don't road trip much so it's not a huge inconvenience for me.
You can hear the pumps spinning away open up the trunk or from the car. Pull the fuse they stop. If they were locked up I shouldn't be able to hear them??I built my custon fuel system with dual pumps and a return line. Since that time, its been driven 6hrs each way to the beach. 8hrs each way to southern GA. No pumps shutting off.Sounds to me like your pumps are seizing. You said you have aero pumps right? Have you looked in your tank? Look for fine black shit floating in the tank. Your pumps not pumping and registering 0 psi has nothing to do with them not being able to pump hot fuel. Pumps are designed to be in fuel pumping. The fact that your pumps STOP pumping should tell you something is wrong with them. And I would suggest fixing the problem before you destroy your engine you just payed for.
I'm all for getting it fixed but to this point don't know what it is if you say it's not hot fuel.
If there is debris's in the tank the pump would not start pumping fuel. If something gets caught in it it don't just leave it stays there till it gets removed.
I know your trying to help and I do appreciate it so don't take this as me not thinking your trying to help
Posted 22 August 2011 - 10:39 AM
