Fuel Additive For Winter Storage? Yes Or No?
Posted 26 November 2011 - 03:03 PM
Posted 26 November 2011 - 03:05 PM
Posted 26 November 2011 - 03:08 PM
Posted 26 November 2011 - 03:25 PM
Posted 26 November 2011 - 03:35 PM
Remember ethanol is hygroscopic... But, as the fuel system is considered a closed system there should little water in the gas even after a few months of sitting. But if you have a boat that has a vented system you best use something.
2010 Stone White R/T
Posted 26 November 2011 - 03:39 PM
Mods:
None
Sold:(Traded) 2/26/12
Posted 26 November 2011 - 03:50 PM
Posted 26 November 2011 - 06:21 PM
After reading the Aol article on gas.... I will be sure to add some Stabil this week coming up. Thanks for the info.
530 rwhp 458 trq
Posted 26 November 2011 - 06:22 PM
Posted 26 November 2011 - 06:28 PM
Even if it was a metal tank , if it is stored in a garage it is highly unlikely to condensate. Due to temperatures not changing quickly, stale fuel is more of a problem. Like Mike said leave the level low and top it off in the spring with fresh gas.difference is this isnt an airplane, we are talking about a plastic tank that also doesnt have a return line that never sees the sun
Posted 26 November 2011 - 06:40 PM
Cheap and can't hurt.
Posted 26 November 2011 - 06:51 PM
I mean they say
"ADDED TO GAS OR DIESEL:
Marvel Mystery Oil® lubricates the entire fuel system-fuel pumps, fuel injectors or carburetors and the top-portion of the cylinders. These are areas, that by design, motor oil does not reach. Using Marvel Mystery Oil® in your fuel extends the life of these vital components by providing them with lubrication that fuel alone does not provide."
I mean it says the top area of your cylinders need lubrication
Do you think Stabil is going to keep Ethanol from evaporating? Like I said I would leave it low and add fresh before start up.
Posted 26 November 2011 - 06:56 PM
Posted 26 November 2011 - 07:10 PM
Posted 26 November 2011 - 07:21 PM
But, SeaFoam is Pale Oil , Naphtha and Isopropyl Alcohol.
Posted 26 November 2011 - 07:37 PM
Posted 26 November 2011 - 08:20 PM
I hope people know that Naptha and Mineral Spirits are Paint removers. They are the 2 key ingredients in Wax & Grease Remover. So would you pour that into your oil?
Great thread.
Mike would know about all things paint. Great advice. If I may ask another question guys...
I keep mine in the garage and during winter IF there is not a lot of salt on the roads and it's sunny out I'll go for trips. But if she sits for say a month in the garage, last year I would at least once a week start her up for 10-15 minutes. Talking to Roger and Jim yesterday about it and the feeling is that in the future I should run it for the 10 minutes a week and right before shutting her off while in Park (of course) I should go WOT for just enough to blow out any water in the exhaust pipes.
Also, I don't have the room to put my car up. So should I pump the tire pressure up high or something if she's gonna sit for a month at a time?
Any other thoughts on how to handle things?
Maggie w/8lb boost upgrade (Installed by Tracey from HHP)
Kenne Bell boost-a-pump
Builder Bill NAG1 stage II modified valve body
Legmaker CAI
Dayco tensioner
AEM/Razors Edge AFR/Boost gauges
Drive shaft loop
Zoomers cat-back exhaust
Jet 180 T-Stat
Moroso Oil Catch Can
Mopar coil overs
Mopar rear sway bar
(When at the strip club): Set of rear 17" Weld rims/Hoosier 275/40/17 DRs
Iron foot.
Custom dynotuned by Josh of HHP
PB: 11.116 @121.47mph at Atco on 12/10/11 (with above mods including bogart/M&H racemaster skinnies and 1/4 tank of gas with 2 gal of 103 race fuel on top)
Remember, use the internet as a tool...don't become one using it.
Posted 26 November 2011 - 08:51 PM
Posted 26 November 2011 - 08:52 PM
