High Boost Piston Yea Right!!!!!!
NOT builder related
29 replies to this topic
Hemituner
Hemituner
  • 1,067 posts
Well This goes to show you that it dosen't matter how much real estate you put above the ring land if you leave like .020 at the eye brow to burn off and waste your engine.
18 lbs on C-16 20 deg timing 11.8 Afr PHAIL.
Hemituner Performance
100 Dale Street
Westbabylon NY.11704
516-603-9276
08 Dodge Challenger Procharged 8.71 159 Under Construction
06 Dodge Charger Arrington IRON 440 V2.0 with 92mm TB, Paramount Trans and 8.8, DSS Custom Axles, Pro Torque Billet Stator Converter, Arrington CAI, American Racing 3 inch Cat Back, American Racing 2 Inch Headers
ALL MOTOR [email protected]
TWO TIME MSHS STROKER CHAMPION 2011 2012
  • 18,597 posts
vroom vroom...
  • 8,116 posts
Dam AJ, Do you not think having flat tops would help with that? More meat? I never liked a dish piston and would always have higher CR dome pistons cut down to flat tops to get the CR I wanted. Is that possible on these newer hemi pistons?
Hemituner
Hemituner
  • 1,067 posts
Well if you look at where the failure occured making it a flat top really won't help it. You really need the bore to be bigger to add enough material if your cutting a large relief. Search the web for pics of these engines you won't believe how many pistons are thin like that. We can get thick flat-tops pretty much for any application and get creative with compression. Flat top pistons are so good in so many ways I try to run them whenever possible.
100 Dale Street
516-603-9276
  • 8,116 posts
Ok, I was just thinking if it had some more material on the other side of the valve notch. The eye brow might not have lifted off as easy? Like these older Hemi pistons. I had over sized valves on a 426 one time and actually had to have that eye brow shaved off the pistons.
Tout
Tout
  • 3,077 posts
AJ
Add a little more information
How long in use
What kind of use race only or daily driver also
CR of engine
type of blower
Nitrous if so how much
Piston material
We have been ceramic coating the pistons to help with heat issues on highly boosted/nitrous applications.
Tout
2011 Dodge Challenger Dragpak 8.54 @152mph single 250 shot MPH Racing Tim Barth Arrow Racing Engines2015 white Hellcat Challenger auto,
Bill, you owe me 8300.00 for the Rossler TH210 trans you stole, can't wait to see the day when the  guy's you have your grubby hands in their pockets figure you out for the thief you are.........I wouldn't do business with anyone that you are associated with, thieves always hang together..............
srt5939
srt5939
  • 9,818 posts
Who's piston is it?
8.92 at 154mph
Hemi by  Hemituner
J-Z
J-Z
    VACATIONER
  • 2,702 posts
I know its hard to see here but I was worried also when I first saw my eyebrow, Not alot of meat there.At least there coated I guess.
MoparManiac
MoparManiac
  • 933 posts
Who's piston is it?
It was tagged as a Weisco failure.
srt5939
srt5939
  • 9,818 posts
Who's Weisco piston is it?
Is that better?
8.92 at 154mph
Hemi by  Hemituner
Tout
Tout
  • 3,077 posts
I thought there was a discussion on Wesco pistons a while back, could have brands mixed up????
Tout
  • 15,029 posts
So shaving that area is the solution?
  • 10,316 posts
Tout
There was a Buckwheat rant on them that involved Andy if I recall correctly...it had more to do with the block than the pistons...again, if I recall correctly.
And I might add, none of the blame was on Andy.
Andy@PWR
Andy@PWR
    PARTS GUY
  • 4,608 posts
Thats the old Wiseco piston design. That thin spot became an issue when high heat was present. Wiseco has since changed their design to eliminate the thin spot as has Manley.
A flat-top isnt going to help as your still going to have a thin spot right there at the valve relief. The solution is a smaller valve relief or the angle mill at the surface to eliminate the thin spot.
If this is the motor I think it is, it made 1100rwhp and was built by ERL with a Twin Turbo Creations turbo kit on it.
This is the old style Wiseco piston with the thin spot at the relief.
Here is their newer design. They actually angle mill the face to eliminate the thin spot.
  • 15,029 posts
I've been trying to find a picture of the 2618 Mahles in my motor. I think they had that angled relief as well. I'll have to check my pics when I get home.
Andy@PWR
Andy@PWR
    PARTS GUY
  • 4,608 posts
Im 99% sure the Mahle's do have the angle mill as well.
Will update in a little while with video and sheet. Time for a leakdown and 3 bar mapsensor.
  • 15,029 posts
^^ That yours Andy?
Was there detonation of some sort / tune off?
Paramount driveline
9.20 @ 152.42mph 1/4
5.29 @ 133 1/8 1.25 60'
Andy@PWR
Andy@PWR
    PARTS GUY
  • 4,608 posts
^^ That yours Andy?
Nope, ERL built this, but the builder couldnt have prevented it. It could have just as easily been me but it wasnt.
  • 8,116 posts
That is how the older Hemi pistons are machined on the edge also.But I also machined the whole lip off of my 426 pistons there was enough meat there to do it. It also seems the pressure getting down inside the dish puts more strain on the valve notch than a flat top also? But the piston you show does not have much of a dish like the first one AJ posted either. Forged pistons are much better than cast ones with out a doubt. But with forged ones just being pressed into shape, bends and edges are weak like any other pressed metal. I have never checked and I am sure it would be very expenseive compared to forged pistons, but a set of cnc machined billet pistons would fix all our piston problems I would think?
