Clutch (Spec) Or T6060
51 replies to this topic
dodgetime
dodgetime
    CAVU
  • 2,892 posts
made a couple runs last night at the dragstrip. First run third gear attempt failed, not missed, it wouldn't take it, I backed off pressure and it went on in, quick time.. So I hot lapped and while in line noticed some new chatter going on and a one time slip and grab while moving forward, something new going here. It staightened up some so decided to go ahead with burnouts and run. Again third locked out, released slitght pressure and in with a short slight high grind (that's when the 5.0 Mustang went on by). I know some 6speeders have had some issues, what say you? and what repairs upgrades available? definetly thinking another clutch. I drove on home after that run no problem and today no problem under normal driving everything is fine but the clutch is having issues.
  • 8,149 posts
Most like the Spec, but I have heard really good things about McCleod as well. Personally I would still go with Spec as I appreciate their support of our little event and that does matter to me. Next time we get together, you can take mine for a spin and see.
dodgetime
dodgetime
    CAVU
  • 2,892 posts
I plan to get a look at the clutch up close in the near future but isn't there some syncro upgrades also?. While apart worthwhile having some love thrown into the transmission if there is some latest and greatest..
  • 8,149 posts
Sam and I had Hanlon Motorsports in PA go though and beef up out trannies. Bob is one of the big guns when it comes to Tremec and a nice guy to deal with. I think your '10 has better synchros than the 09's had anyway.
TorRed Dave
TorRed Dave
  • 617 posts
I talked to the ACT rep at the NMCA event in Atlanta 2 weeks ago. He said they will be releasing their line of clutch assemblies for the late model Hemi's in the next few months. Im sure they'll be priced about the same as the Spec.
www.advancedclutch.com
 2010  SRT/8 6 Speed w/bolt on's.   OST Tuned   B)
do you already have a spec clutch or are thinking of getting one? if you have a spec, is it the p-trim or ss?
Paramount driveline
9.20 @ 152.42mph 1/4
5.29 @ 133 1/8 1.25 60'
dodgetime
dodgetime
    CAVU
  • 2,892 posts
had a SS trim 900T installed about a year now bout 7000 miles on it, bout 6, 1/4 mile passes
  • 18,572 posts
It's your trans, DT. You'll find the clutch is fine IMO. Your synchro is going. Check the fluid for grins but I'm guessing the Tremec is going to seed like mine did early on.
dodgetime
dodgetime
    CAVU
  • 2,892 posts
that's brutal Sam, total shitzky huh. IDK that clanking and chatter is new although brief defo the clutch. Seems ok driving the girl around like it was intended ya know? you right will crawl under this weekend chk fluid. Assuming it is the trans, is there a jobber that works these units and core swaps? that'd be the ziggy.
  • 18,572 posts
that's brutal Sam, total shitzky huh. Seems ok driving the girl around like it was intended ya know? you right will crawl under this weekend. Assuming it is the trans, is there a jobber that works these units and core swaps? that'd be the ziggy.
Mine only had the problem under load (i.e. getting on it). It was intermittent when I was stock and then after a while it got pretty frequent at the strip. Eventually 4th started giving me a problem.
I used Hanlon, as Chuck mentioned. He went before me. I like mine real well once it's warm. It struggles a bit with the 1 - 2 shift when it's cold. Liberty also does them. I really enjoyed working with Hanlon...good people and reasonable price. They set up the shipper, etc... pm me if you need details.
P.S. don't use but one quart of that really thick stuff they recommend to there of some ATF. I use Mobil 1 for the other 3 qts.
J-Z
J-Z
    VACATIONER
  • 2,702 posts
RAM CLUTCH!!!
RAM CLUTCH!!!
With you it's always ram everything. Ram clutch, get rammed in the butt, blah blah blah
Paramount driveline
J-Z
J-Z
    VACATIONER
  • 2,702 posts
Only thing I ramed last night was your wife and mom.How are they doing today btw? They were pretty sore last night.
JZ starts making out with a chick, she takes off his shoes and socks, and sees his toe is all shriveled up. She's like, "whats wrong with your toe?"
He says, "oh I have toe-lio" She says, "you mean POLIO?" He's like, no TOE-LIO!
Then she takes off his pants and sees his knee is all messed up. She says, "wtf is wrong with your knee?" He says "oh i had kneesles" She says, "you mean MEASLES?!" He says, "no!! kneesles!"
finally she takes off his boxers, takes one look and says "let me guess, smallcox?"
Paramount driveline
dodgetime
dodgetime
    CAVU
  • 2,892 posts
so many little afflictions, whats a guy todo, conversation pieces at least :D
J-Z
J-Z
    VACATIONER
  • 2,702 posts
ha ha,Did speddy tell ya that one?
  • 18,572 posts
RAM = chatter...
J-Z
J-Z
    VACATIONER
  • 2,702 posts
Only if you dont know how to use it. ha ha
Thats why Lakeys going with an auto,hes to much of a vagina to properly race a 6 speed
Paramount driveline
  • 18,572 posts
JZ....you still remember how to drive a stick???? Got pictures from way back when...
