Clutch (Spec) Or T6060
#21
Posted 28 April 2012 - 04:02 PM
#22
Posted 29 April 2012 - 04:03 PM
You were unfortunately right Mike
2015 Charger Hellcat (Wife's new ride) [email protected]
2013 GC SRT8 The daily ride
Craig
#23
Posted 29 April 2012 - 04:18 PM
#24
Posted 29 April 2012 - 04:45 PM
Arrington aluminum 426. Twin 67mm turbos. Nitrous outlet direct port
Paramount driveline
9.20 @ 152.42mph 1/4
5.29 @ 133 1/8 1.25 60'
#25
Posted 29 April 2012 - 05:47 PM
#26
Posted 29 April 2012 - 08:01 PM
Craig
#27
Posted 29 April 2012 - 09:58 PM
Paramount driveline
#28
Posted 30 April 2012 - 03:43 AM
Craig
#29
Posted 30 April 2012 - 04:15 AM
Cool, I am going to order the Spec SS. Seems like Challengers running this clutch are working well.
If you wamt to shoot me a PM with your best price found before you pull the trigger I may be able to save you a few bux. After recpt of mine and comparing weights with stocker I sent the flywheel back in for lightening. My gut tells me they are designed for 3 passengers, baggage and full saddles. That is not how most of us roll. I figure mine spins easy enough now and more RPM's are available if need be launch wise. Acceleration once hooked will certainly be better and less weight up front is another small benny. May wish I didn't but what the hey, learning what works and doesn't is a lot of what we all do here.
#30
Posted 30 April 2012 - 10:13 AM
At CF3 I was spinning slicks on the launch, and my buddy says the clutch is A OK from watching it launch. Sounds like you may just be overheating either the clutch, fluid, or clutch master cyl. Try giving a few mins to let it cool and see how it does.
I've got 50-60 runs on the car now, and every single one of them has been at or above 550RWHP. 95% of those runs was on DRs and since I don't have a line lock I'm putting extra stress on the clutch holding the brakes for the burnout.
#31
Posted 30 April 2012 - 12:43 PM
I'd go SPEC SS-trim. It's plenty and it's what I run putting down a reasonable amount of mojo at the rear wheel. Another option I'm hearing good things about is McLeod. Apparently smooth as butter and now available for our rides. I can't speak to them personally, though.
Posted 30 April 2012 - 02:28 PM
Y'all convinced me (heck if it works on your 10 sec ride should work great for my slow poke). Ordered the Spec SS today. I also got the line lock system from Alan so no more fuckin around two footing it at the line. I know that is how I fucked up my stock clutch and I also think that with slicks you stress out the clutch way more than with DR's (hear that Speedy). Now I got to pull the tranny this weekend oh joy oh joy.I'd go SPEC SS-trim. It's plenty and it's what I run putting down a reasonable amount of mojo at the rear wheel. Another option I'm hearing good things about is McLeod. Apparently smooth as butter and now available for our rides. I can't speak to them personally, though.
Craig
#33
Posted 30 April 2012 - 02:32 PM
#34
Posted 30 April 2012 - 03:02 PM
https://millerspecia...?id=1565&gid=18
Posted 30 April 2012 - 03:13 PM
Sam let me move his car at CF3 and the SS trim is AMAZINGLY easy to drive compared to the p trim.
go for the ss trim, its more than youll ever need.
#36
Posted 30 April 2012 - 04:20 PM
hope you got a lift. i did it on jack stands in my garage. not fun.
Paramount driveline
#37
Posted 30 April 2012 - 04:46 PM
Absolutely, was the best purchase I ever made. Not only is it a piece of work to work on the car but I get to store a car under the one on the lift,hope you got a lift. i did it on jack stands in my garage. not fun.
Craig
#38
Posted 30 April 2012 - 04:56 PM
Paramount driveline
#39
Posted 30 April 2012 - 05:02 PM
Cool Craig....code is still active I assume ? No need for MMFers to pay in the teens of hundreds for one of these.
#40
Posted 30 April 2012 - 05:10 PM
PM'ed ya bud. ThanksCool Craig....code is still active I assume ? No need for MMFers to pay in the teens of hundreds for one of these.
Craig
