Realistic Hp Gains For A 5.7 Vvt From A 6.1 Intake?
Posted 26 May 2012 - 02:30 PM
http://www.shophemi....e-manifold.aspx
With the proper adjustments to the tune, what sort of HP gains, if any, could I expect? I believe the gains are less in the 2009 and newer 5.7s due to a more efficient albeit plastic intake manifold.
And this comes with a throttle body? Is that beneficial? Will the 5.7 T.B. work on the manifold, or does thbe 6.1 T.B. improve performance? Thanks!
Posted 26 May 2012 - 02:51 PM
I
Posted 26 May 2012 - 03:00 PM
I'm fairly certain that they both come with the same throttle body, at least when you order an aftermarket one they generally list the same for both motors. The 6.1 intake has a 82-85 mm opening (depending on who's write up you want to believe) so if you aren't going to do any porting probably 85mm is as big as you want to go. However since the 6.1 intake is aluminium you can certainly open it up larger and add a 90mm or larger if you would want to.
Posted 26 May 2012 - 07:08 PM
As I recall, the TB's, stock, are the same.
If you were looking at a centri blower, then this is.something to consider...
Posted 27 May 2012 - 06:55 AM
The 6.1 manifold flows 1 cfm better than the stock manifiold in the Eagle heads. The benefit is you can do more to an aluminum manifold than you can a plastic one.
What he said except I thought it was 3cfm less than a 6.1. You can pick them up used from 6.1 guys upgrading for less money. I think for similar money you can get better gains from a installed cam with a cmr. Believe me those eagle bits flow well enough unless your looking to do huge things in your build.
2005 Black Chrysler 300c:
FRI/d: Decked .030 Street/Strip Heads
STU/d: SRT Max camshaft
AJ Berg Sunoco 93 Octane Tuned
STU/d 400CI Stroker on deck
Posted 27 May 2012 - 07:08 AM
Posted 27 May 2012 - 07:10 AM
Unless Arrington chimes in on Tuesday with some amazing info to the contrary, I think I'll just put the money towards the new VVT cam packages that are now starting to appear out there. I was looking for something fairly easy I could do myself out in the garage - intake mannys are pretty routine - I've done a few of those in years past on Chebbies.
If I did change the heads at some future point, then the intake manifold would be good to do too, because it can be ported/polished to match the heads - an obvious advantage over the plastic stock one, besides appearance.
Posted 27 May 2012 - 10:45 AM
http://www.youtube.com/watch?v=c6si8Xp8P-M
Damn I love that scene...
Posted 27 May 2012 - 12:31 PM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 27 May 2012 - 12:47 PM
Posted 29 May 2012 - 08:32 AM
With that said, I would not drop the coin on a new complete kit for that price. I got my intake for $460 shipped with everything except for the throttle body and throttle body bolts. Our throttle body is the same, so don't need to purchase a new throttle body, but I will have to buy some throttle body bolts as they are different. The intake bolts are also different, but mine came with them. I have not installed the intake yet, so I don't have real world numbers. If you can find just a bare intake, I have an extra set of 6.1 injector rails and injectors, and I would make you a good deal on them.
09 Challenger RT, 6-speed, Eibach Sportlines, stock 6.1 Headers, MF mid-pipes, Dynatech mufflers, Matte Black 20's, fuzzy dice, and many plans!
03 Dakota RT, ported stock heads, Hughes cam and valve springs, Hughes/Edelbrock intake, F&B 58mm throttle body, Gibson headers, Flowmasters, Cal-tracs, 4.56 gear, & D1SC Procharger
12 Grand Cherokee Limited, 4X4, Hemi
Posted 29 May 2012 - 09:16 AM
You have to create a need for that additional airflow before the manifold swap will show a gain.
Posted 29 May 2012 - 10:02 AM
Diablosport CMR Dealer
Screaming deals on Trinity's, Trinity's with wideband, Trinity w/tune discount.
www.OSTdyno.com
Email: [email protected]
Posted 29 May 2012 - 11:49 AM
The 6.1 intake will make more power higher up in the powerband than the eagle.....especially when ported. Do a VVT cam you are going to want more intake manifold anyway unless the cam runs out of power under 6k rpm.
Erik & I just did this to my 5.7 VVT HEMI. My 6.1 was ported & polished and I noticed a difference. The car pulls to 6,500 RPM
Posted 29 May 2012 - 01:19 PM
Posted 29 May 2012 - 01:35 PM
Cliff's Notes from above link:
"So what does this mean? For pretty stock 09+ R/T applications the Eagle (manifold) is probably the best bet, but once you start to extensively modify them the 6.1 intake manifold should be used."
Posted 29 May 2012 - 01:42 PM
Modern muscle did back to back test with these manifolds. Ill try and find a link here in a few..
I have seen that write up, but I think it was on a pre-Eagle motor.
Posted 29 May 2012 - 01:51 PM
It was on a 09 Challenger RT. It was to test the difference between an Eagle manifold and 6.1 manifold on a slightly modified Eagle engine. The gains get larger for the 6.1 manifold the more extensive the mods become.
Posted 29 May 2012 - 02:09 PM
Posted 29 May 2012 - 02:15 PM
Here is the article I was referring too..
http://www.moparmusc...es/viewall.html
Different article we are talking about then. I was talking about the one the Novawagonmaster linked.
