392 Heads On A 5.7
Posted 01 June 2012 - 02:28 PM
Has anyone out there swapped a set onto their 5.7 or have any input/opinion as to whether this might make a good bolt on, or would it most likely just be a waste of time and money if the 5.7 is still mostly stock.
Posted 01 June 2012 - 02:29 PM
ANDY????
Posted 01 June 2012 - 02:42 PM
PWR Forged 6.1 block -V7 YSI (18psi)- Modern Muscle ported intake manifold - Indy Heads - Modern Muscle custom cam - TTI Longtube(catless) - Paramount TC/Transmission- 3.06 Getrag-325/45/17M&H
Posted 01 June 2012 - 02:52 PM
Posted 01 June 2012 - 02:53 PM
Assuming you are talking about your Challenger 5.7 (Eagle). The heads that come on that car will support a tremendous amount of power (especially if you have them ported). There are several strokers out there running ported Eagle heads. GTP did one hell of a job on my Eagle heads.
I've got no complaints with mine either, Jon. Arrington built mine.
Posted 01 June 2012 - 03:24 PM
isnt there something about them not fitting without notching the block?
ANDY????
BINGO! I was going to go down this road until I found that out.
Slowest supercharged Challenger. Ever.
Posted 01 June 2012 - 03:29 PM
6.1 heads 822.80 EACH PLUS 250.00 CORE
6.4 heads 449.90 EACH PLUS A 150.00 CORE
09+ 5.7 heads LEFT HEAD 419.10 CORE 150.00 RIGHT HEAD 225.50 + 150.00 CORE
Posted 01 June 2012 - 03:33 PM
I've never understood that... happens all the time with dealer parts (other manufacturers too).
Posted 01 June 2012 - 03:47 PM
Posted 01 June 2012 - 03:53 PM
Posted 01 June 2012 - 04:23 PM
They will clear a stock block, but its extremely tight. You really need to notch the block for the intake valve. In addition to that, the intake valve sits very close to the top of the piston and you will need to measure/verify piston to valve clearance. One final thing, they are actually about $1300 a set now.
I just looked them up again to make sure and they list them for 449.90 each as you say, they don't say anything about a core charge that I can see, but of course that doesn't mean that there isn't one or that they would even have any in stock.
I kind of figured there would probably be more to this than just bolting a set on, otherwise I would have thought I would have read about guys doing it by now. Oh well I was hoping for a relatively easy bolt on with minimal (hopefully none) machine work.
Posted 01 June 2012 - 04:31 PM
They will also lower your compression a full point.
Posted 01 June 2012 - 09:16 PM
Ok so now it's sounding less and less benefical all the time
Posted 02 June 2012 - 01:57 AM
Posted 02 June 2012 - 09:39 AM
Unless you want to boost
Yeah I thought about that too, and notching the block isn't necessarily a big deal other than I don't want to get into that much work at the moment. Mostly I was just curious, as a head upgrade generally seems like a natural thing to do for most motors and I haven't really read much about the 5.7 guys upgrading their heads. It may be as Nova said that the Eagle heads are good enough (especially when ported) to take care of most peoples needs.
Posted 02 June 2012 - 01:04 PM
http://pwrparts.com/...products_id=106
Posted 06 June 2012 - 12:13 PM
Posted 06 June 2012 - 07:05 PM
2.14 x 1.64. I might be slightly off on the exhaust.
Posted 07 June 2012 - 10:21 PM
