2010 Challenger Srt8 Help!! - Abs, Esp, And Trac. Control Lights On
Posted 16 September 2012 - 10:36 PM
They came on after I started driving for about 5 minutes or so...car drove fine so I just kept going from Baton Rouge to New Orleans and back...like I said, car ran like normal the entire trip. I even pulled over, turned the car off and on, and pulled the ABS fuses to no avail.
So, any ideas? Car is still under warranty, but if this is something I can fix really quick myself, then I would obviously prefer that route. This is my DD so I'd prefer not to have to skip work and/or school to sit around at a dealership all day.
Thanks in advance for any and all help!
Guest_HemiRob_*
Posted 16 September 2012 - 10:46 PM
Guest_HemiRob_*
Posted 16 September 2012 - 10:48 PM
Posted 17 September 2012 - 12:53 AM
Restart and go for a drive. Not sure if that's your issue but it's easy to try.
Posted 17 September 2012 - 06:17 AM
Posted 17 September 2012 - 06:24 AM
Did you try holding ESP button in, until the lights go off ? That shuts the system down, but then should reset when you start the car again. Hopefully the light will stay off.
I was just wondering if your car has a race tune or has been raced?
If so, then you probably would need to go for sure and get the codes cleared.
We had to with my car.
Linda
The "Pink Car" Awesomely Built and Tuned By Tim Barth [email protected]
Tim 6/3/2012 ET 9.18@ 151 mph KB 4.2 ~ Street Legal/Full Weight/IRS! Linda ~10/27/13 ET 9.49 @ 144 mph
Goal Is 8.xxx "New HHP" AL Block @ BES getting Built!!!!
11/27/2015 Fastest Hell Cat Charger In the World! ET 9.71 @ 140 MPH
Posted 17 September 2012 - 06:27 AM
Hi,
Linda
Line lock really pisses it off as well. but the OP said he had no tuner/scanner so I am guessing he's stock. I would go by an AZ of such and just get it scanned.
Posted 17 September 2012 - 07:35 AM
I'll probably swing by AZ on my way home today and have the codes read just so I'll know for sure. It should be fine to drive though right? Just have to be a little more careful? This car is my DD.
Posted 17 September 2012 - 10:26 AM
Performance Mods:Predator,Kooks Long Tubes,Solo Catback,3200 stall,3.91 getrag.
12.22 @110.87
Posted 17 September 2012 - 02:39 PM
Keep us posted on your findings. My light also comes on once in a while then goes off on its own.
Will do. Autozone couldn't read the codes, apparently their scanner doesn't pick up ABS codes. Going to the dealership tomorrow at 10.
Posted 18 September 2012 - 10:55 AM
Posted 18 September 2012 - 12:49 PM
Unfortunately no I cannot. I don't have a scan tool or tuner and this started this evening so no free Autozone/Advanced Auto diagnostics either.
No tools needed to pull codes from a Dodge. Using the key, turn ignition to "on" position (do not start), bring back to off, on,off,on in less than 5 seconds and codes will show up on the odometer.
On-off-on-off-on trick has worked on Dodges since the mid 80s. My 85 omni eid this too.
Posted 18 September 2012 - 12:58 PM
Posted 18 September 2012 - 06:03 PM
That is something interesting to remember!
Glad it all got worked out!
Linda
Posted 18 September 2012 - 07:51 PM
So did my 84 laser, however back then it was the Check Engine light that flashed. There were only like 10 or 11 codes that were possible back then, and they were in the owner's manual if I remember right.
Posted 18 September 2012 - 09:50 PM
I really need to start getting into some mods on this car though. I'm so tired of stock exhaust. Also, for anyone in Louisiana, I'm thinking about trying to go to No Problem on Saturday night. Cool weather should make for some better than normal at the time of year DA. I want to get a baseline on this car before I mess with it...even though my mod list is pretty short.
Posted 19 September 2012 - 12:00 AM
Posted 19 September 2012 - 04:13 AM
I think Saturday night is the local bracket racing night at No Problem. Wednesday nights are usually test and tune nights, just FYI.
Lisa, How often do you Race?
Linda
Posted 19 September 2012 - 05:20 AM
I've heard of the key trick, but I also heard it only worked for the R/T's? Hopefully I don't get any other codes again so I won't have to try this trick,
This isn't the key trick. That has to do with traction control deactivation. This key sequence is for code checking.
Posted 19 September 2012 - 05:24 AM
Linda
Not near enough. It depends on how long Red Monster spends at Southern HotRod after I have broken him again
