2012 5.7 To 6.4 Cam 60/36 Gain!
136 replies to this topic
#21
!FST4DR
!FST4DR
  • 1,515 posts
Heads,CI, duel runner intake, exhaust manifolds,..
!FST4DR
!FST4DR
  • 1,515 posts
Was that car "tuned" before the cam went in?  If not then it does make more sense as 25 rwhp can be achieved by just a custom tune.
chris1992
chris1992
    CF3 Index Winner
  • 757 posts
^^ that's what I've been curious about. I'm assuming the base dyno was on the stock tune, no?
  • 10,496 posts
So that's another one showing a nice gain with a 392 cam.  Hmmmmmm.
#25
!FST4DR
!FST4DR
  • 1,515 posts
Another?  Where was the first 60 rwhp gain?
  • Validating
  • 10,095 posts
Sixty is the biggest I've read about, 40 was the number mentioned most often.
Wish I could have dyno'd mine with just the cam.
!FST4DR
!FST4DR
  • 1,515 posts
Ive seen 30 myself.. I honestly was quite shocked to see 60.  My tuner has done plenty of these cams and he agreed that he is never seen that much of a gain.  But good for Brian  He must of found something the rest of us haven't.
  • Validating
  • 10,095 posts
Yep, exactly.
  • 10,496 posts
Mopar Medic claimed to have a 392 cam in his KB 5.7 and said he gained 60 on the dyno.  His is supercharged though.  Didn't Mike at OST say he saw a good bump from these as well?  I may be mixing things up but I coulda sworn he said he could advance the cam in the tune as well.
#30
  • Validating
  • 10,095 posts
He hasn't mentioned that to me, but then again I haven't really brought it up either.
blk09rt6sp
blk09rt6sp
  • 128 posts
what was the install cost on the cam?
!FST4DR
!FST4DR
  • 1,515 posts
apples and oranges dont ya think?  On a side not why note add 60 hp with just a pulley swap?  Much cheaper I would imagine..
  • Validating
  • 10,095 posts
 Why not do both?
BlackVoodoo
BlackVoodoo
  • 3,479 posts
edited. I have piss poor reading skills.
PWR engine giveaway winner.
Why yes, my balls DO feel bigger, thanks for asking!
www.facebook.com/ModernMoparMilitia
#35
  • 10,496 posts
I don't know why your splitting hairs on this, maybe because you guys couldn't get 60RWHP out of your installs?  Regardless, I just originally said this is another case showing good gains, I never said "hey here's another drop in 392 cam on a 5.7 that picked up 60RWHP".  This is the most I've seen on a standard non blown motor.  I've heard from more than one place the 392 cam works a LOT better on supercharged cars than NA but have not seen a back to back NA vs. Supercharged comparision other than Sean and Phil at CF4.  Phil picked up some good torque if memory serves, but only a few horse power.  He was on the stock tune though, and Sean was having some weird knock issues that were later resolved so the data isn't really valid.
As for why not add a pulley, you'd have to ask MoparMedic but my guess is he's at 8psi and on a stock motor and doesn't wanna blow it up.
#36
  • Validating
  • 10,095 posts
Once the knk issue was resolved, my car, at 6-7lbs of boost, with the 6.4 cam made 477/448.  Best prior to that was around 34X/37X on the same dyno.  There appears to be a lot of evidence now that this is a worthwhile mod.  To answer the earlier question, Brian (the OP) put cost in an earlier post.  The 6.4 cam is the inexpensive part, most other cam options are significantly more....install and tune are going to be roughly the same no matter what cam you choose, and I haven't seen a lot of data out there on the other VVT options, however other folks may know more about that.
Again, nice work Brian.
  • 10,496 posts
The only other VVT option I'm aware of is the COMP VVT cam that's like $800 with a phase limiter and is a bear to tune.  Makes great power if it can be tuned properly though but it sure better for the price.  The tuning is so tricky Mike charges by the hour to tune one of those.  The cam is about $55 at my local dealer so it's cheap.  The typical buyer will also need valve springs.  I'm not sure how much those cost.  Then the install labor if you're not doing it yourself.  It's not super cheap for 40 - 60 RWHP after all is said and done, but not super expensive either.
I've been considering one for a while since I already have upgraded valve springs.  For me it'd just be pulling the front cover and swapping the cams.  I've just been waiting to see if anything else would be coming.  Here we are coming up on 5 years with the VVT cars and now ALL of them are VVT and we're still not seeing much.
#38
  • Validating
  • 10,095 posts
Yup, and no one seems to keep them very long.
Andy@PWR
Andy@PWR
    PARTS GUY
  • 4,031 posts
We have done 3 custom grinds. With the new tuning, its working great. Got a 410ci vvt motor that we are finishing up for brian that has thitek heads and a 23x/24x vvt camshaft going in it.
If you didnt hear it with your own ears or see it with your own eyes, dont invent it with your small mind and share it with your big mouth!
there is no competition.
#40
  • 10,496 posts
What are the details on the three you've done?  Can you share the specs and power output?  Anything for my 6.0?
