Parting Out, Huge Sale!
123 replies to this topic
Some item pricing is negotiable in private PM and I can do some group item discounts.
New 393 PWR race engine long block 10,500.00 out right (no cores required) SOLD
only comes as a long block as heads are oringed with the block.
comes with custom cam.  shipping not included. Built to handle 25+ lbs boost
Nitride Hardened Scat Crank, Callies Ultra Rods, Manley Custom Pistons, Manley Rings and Pins, Clevite Bearings, ARP Main Studs on Billet Caps, Machined with 1/2" Head Studs, Oringed Heads & Block and Custom Cometic Copper Gaskets. PWR built Race heads (Ferrera), timing set installed, 1/3 fill concrete
Cam Specs-Lobe Lift:                                                          .370”                  .370”  Gross Valve Lift 1.65 Ratio:                   .611”              .611”
Duration @ .050” Tappet Lift:               231*             239*
Lobe Separation:                                         116* Recommended Intake Centerline:                  112*
SHR Racing Transmission (used. less than 10k miles, 50-60 passes) 2500.00 shipped (eastern USA) further distance can be negotiated SOLD
Not "Viking" this is a 2010 transmission. There was only 1 model SHR transmission back then
ProTorque Custom Converter (billet stator 4000k stall) Barely Used (30 passes/40miles)350.00 Shipped
ATI SuperPlate High HP Flexplate Barely Used (30 passes/40miles) 125.00 shipped (USA)
8.8 Rear End TruTrac 3.55 gears, DSS axles, 2 piece CM Driveshaft SOLD
Bogart 15"Rears with Tires Mounted. MT 29.5/10.5-15s tires 1200.00 shipping not included Tires are Brand New! SOLD
Bogart 17" Fronts MH 28" skinnies mounted (Tires New) 1400.00 plus shipping (sold)
TCE Wilwood 15" Drag Rear Brake system (installed but never used) 900.00 Shipped (USA) (970.00 w/2 sway links) SOLD
B&M Transmission Cooler w/Fan New 175.00 shipped(USA)
2 Turbosmart 45mm HyperGate wastegates (mounted but never used, will need a new flanges for each) 525 for both shipped(USA) SOLD
2 Precision 6766 Turbos journel bearings, T4 flange .81AR, Ported S compressor housing. 1600.00 for both plus shipping SOLD
(will throw in 2 DEI turbo housing covers)
Custom PT2000 type intercooler  800.00 SHIPPED SOLD
Core Size 14x10x4.5
Overall Size 13" tall 14" wide 17" deep
3.5" V band inlet/outlet
1.25" NPT inlet/outlet
+ 1/2" NPT port (coolant temp)
Pressure Tested to 55PSI
8 Custom FiveO 1400cc(133lb) Injectors 700.00 Shipped (USA) SOLD
Custom Ice Box w/internal pump 400.00 plus shipping SOLD
Moroso Oil Pan has 2 return posts welded in to the front (SOLD)
TreadStone Twin Turbo 9 Intercooler NIB 400.00 Shipped (USA)
  • Core Size, 25" X 9" X 3.5"
  • Overall lenght 28"
  • 1-3" outlet and 2-2.5" inlets
  • 1950 CFM flow rate
  • 1300 HP efficient
FAST dual wide band monitor #170402 NIB 325.00 Shipped (USA)
Aeromotive Billet Electric Fuel Pump Controller #16306 NIB 100.00 shipped (USA)
Aeromotive Eliminator Stealth Fuel Cell #18662 NIB 650.00 Shipped (USA)
Fuel Cell, Aluminum, Natural, 15 Gallons, Built-in Eliminator Fuel Pump, Pre-filter, 0-90 Ohm Sender, Each
Hand Ported 6.1 exhaust manifolds 200.00 (pair) Shipped (USA)
more to come, I have lots of parts. ask me if I have something
  • 12,113 posts
Good luck Bud
  • 7,070 posts
Holy shit! Whas up with the car? Different build route?
Very nice price on the rear end.
Good luck...whatever you are up to.
good_bad_scotch.gif11.71 @ 118.77 mph with a 1.77 60' September 15th London Motorsports Park
  • 17,309 posts
BAM....there it is.  Best of luck with the sale, Mike.  See you in Beeville in a couple of weeks.
Sam
concussion
concussion
  • 492 posts
Damn mike I hate to see this.
Don't sell those rear seats I am coming to get them!!
If you didn't build it, you ain't faster than me.
BlackVoodoo
BlackVoodoo
  • 3,479 posts
Ahhhh, shidoshi going different route? Velly smart move. See you in Beeville and don't be a plick!
PWR engine giveaway winner.
Why yes, my balls DO feel bigger, thanks for asking!
www.facebook.com/ModernMoparMilitia
  • Validating
  • 10,095 posts
EDIT.
GLWS
lots added
Mopar408
Mopar408
    Drivetrain Tester
  • 2,128 posts
GLWS
MOPAR408
2009 Challenger SRT8 - 6SPD
11.55@120 w/ a 1.60 60'
TA340
TA340
    Carbon Fiber Boy
  • 1,620 posts
Sorry to hear this. Best of luck with sale. If deal falls thru on oil pan shoot me a PM. Would be interested. Thx
My Rides
2009 SRT8 Challenger M6 PB - 11.427@ 125.6mph w/ 1.64 60ft
2013 GC SRT8 The daily ride
    6.1 Record Holder
  • 7,540 posts
WTF? you going back to stock? If you are I can help with some parts. I still have a stock Nag1
Tuned by Brent at DTP
bump
GONE
GONE
    Banned by Me
  • 10,848 posts
Edited
Good luck with the sale Mike.
no offense guys but can we keep this a sale thread and not a "this sucks" thread? thank you
bump 17" front runners sold. 15" bogarts still for sale
Drp6982
Drp6982
  • 1,527 posts
How much for the fuel cel ?  Approx weight ?
785RWHP/905Lbs TQ
775 shipped, not sure of the weight. but its pretty light
Dan I can weigh it tonight when I get home if you are interested
bump more added
THE PHANTOM
THE PHANTOM
  • 14 posts
Will yo ube selling the 15" rear convesrion if so i am interersted
the brake kit is 900 shipped (does not include links or bushings as those came separate)
