Some item pricing is negotiable in private PM and I can do some group item discounts.
New 393 PWR race engine long block 10,500.00 out right (no cores required) SOLD
only comes as a long block as heads are oringed with the block.
comes with custom cam. shipping not included. Built to handle 25+ lbs boost
Nitride Hardened Scat Crank, Callies Ultra Rods, Manley Custom Pistons, Manley Rings and Pins, Clevite Bearings, ARP Main Studs on Billet Caps, Machined with 1/2" Head Studs, Oringed Heads & Block and Custom Cometic Copper Gaskets. PWR built Race heads (Ferrera), timing set installed, 1/3 fill concrete
Cam Specs-Lobe Lift: .370” .370” Gross Valve Lift 1.65 Ratio: .611” .611”
Duration @ .050” Tappet Lift: 231* 239*
SHR Racing Transmission (used. less than 10k miles, 50-60 passes) 2500.00 shipped (eastern USA) further distance can be negotiated SOLD
Not "Viking" this is a 2010 transmission. There was only 1 model SHR transmission back then
ProTorque Custom Converter (billet stator 4000k stall) Barely Used (30 passes/40miles)350.00 ShippedATI SuperPlate High HP Flexplate Barely Used (30 passes/40miles) 125.00 shipped (USA)
8.8 Rear End TruTrac 3.55 gears, DSS axles, 2 piece CM Driveshaft SOLD
Bogart 15"Rears with Tires Mounted. MT 29.5/10.5-15s tires 1200.00 shipping not included Tires are Brand New! SOLD
Bogart 17" Fronts MH 28" skinnies mounted (Tires New) 1400.00 plus shipping (sold)
TCE Wilwood 15" Drag Rear Brake system (installed but never used) 900.00 Shipped (USA) (970.00 w/2 sway links) SOLD
B&M Transmission Cooler w/Fan New 175.00 shipped(USA)
2 Turbosmart 45mm HyperGate wastegates (mounted but never used, will need a new flanges for each) 525 for both shipped(USA) SOLD
2 Precision 6766 Turbos journel bearings, T4 flange .81AR, Ported S compressor housing. 1600.00 for both plus shipping SOLD
(will throw in 2 DEI turbo housing covers)
Custom PT2000 type intercooler 800.00 SHIPPED SOLD
Core Size 14x10x4.5
Overall Size 13" tall 14" wide 17" deep
3.5" V band inlet/outlet
1.25" NPT inlet/outlet
+ 1/2" NPT port (coolant temp)
Pressure Tested to 55PSI
8 Custom FiveO 1400cc(133lb) Injectors 700.00 Shipped (USA) SOLD
Custom Ice Box w/internal pump 400.00 plus shipping SOLD
Moroso Oil Pan has 2 return posts welded in to the front (SOLD)
TreadStone Twin Turbo 9 Intercooler NIB 400.00 Shipped (USA)
- Core Size, 25" X 9" X 3.5"
- Overall lenght 28"
- 1-3" outlet and 2-2.5" inlets
- 1950 CFM flow rate
- 1300 HP efficient
FAST dual wide band monitor #170402 NIB 325.00 Shipped (USA)
Aeromotive Billet Electric Fuel Pump Controller #16306 NIB 100.00 shipped (USA)
Aeromotive Eliminator Stealth Fuel Cell #18662 NIB 650.00 Shipped (USA)
Fuel Cell, Aluminum, Natural, 15 Gallons, Built-in Eliminator Fuel Pump, Pre-filter, 0-90 Ohm Sender, Each
Hand Ported 6.1 exhaust manifolds 200.00 (pair) Shipped (USA)
more to come, I have lots of parts. ask me if I have something
