Don And Christian .. Out.
287 replies to this topic
#281
TA340
TA340
    Carbon Fiber Boy
  • 1,977 posts
B&R first thing you should do is buy a Trinity. If you have such a build you need to be able to understand how the car is performing and or why it is not performing. You should also data log all of your drag runs. What is your AFR, what is your timing? Are you getting ST knock? Ect. Ect. Also with the kind of power your car is making and the fact that it is a 6 speed I would not even waste my time going to the strip with street tires. Get yourself some slicks. DR's will work but I like slicks because I think there a little more forgiving on a 6 speed drivetrain.
My Rides
2013 GC SRT8 The daily ride
Craig
#282
B&R Challenger
B&R Challenger
  • 35 posts
6 speeds suck, I would refuse to mod one if I ran a shop, lol.
I agree...
Belt slip is easily checked during data logging. Are you still seeing 11 psi when you were on the dyno last?
Note to self. Dont hire or partner with flybyu. :-)
No, the car has never showed 11psi on the dyno or the pillar gauge.
I certainly appreciate the advice Craig.  A Trinity was ordered for the car this morning and I will look into getting a new rear wheel/tire setup.  Probably end up with a 17" rim and some Hoosier drag slicks.
KW
!FST4DR
!FST4DR
  • 2,351 posts
Ok so was the boost the same on the dyno and the track?
B&R Challenger
B&R Challenger
  • 35 posts
Yes, It read 8lbs on the dyno and at the track.  We rented the track and I had a buddy who tunes (GM's) reading the gauge as we slowly made it to the end.
Jerseyboy
Jerseyboy
  • 1,177 posts
What altitude are you at again?
#286
B&R Challenger
B&R Challenger
  • 35 posts
1100.
Jerseyboy
Jerseyboy
  • 1,177 posts
It's not an altitude difference then.
#288
CruzKing
CruzKing
    blown mother fucker
  • 6,240 posts
I got an pm from aJ  , his old email is no longer good , He did give me all my information  on the heads, and the comp grind, and the info on my torque converter, so i'm f**king good , :D .
thanks AJ , looking forward to see you at MSHS and some shops around here if you visit.  regards, gregory
Camarofest 5 2010
Challengerfest 1 2010
Challengerfest 2 2011
Challengerfest 3 2012
ChallengerFest 4 2013
ChallengerFest 5 2014
MSHS various
PB ET 11.703 MSHS VMP 9/14
PB 60' 1.744 at MSHS VMP 9/14
