I like the new wheels. I think they'll look good.
When I've toyed around with different tires and/or wheels, I've used the website linked below. I know what I have now and how much room I have. I'll compare that to a different scenario and the calculator tells you what the difference is.
This was really helpful. Shows a 10mm difference (+5mm from offset change and another +5mm from going to a 305/35 tire) which I think will be fine. I have about 18mm of space between my current setup and the closest spot of the wheel liner. That's without pounding the hump or massaging the liner with a heat gun.
I like them as well Jay. 20x10 with a +25mm offset is perfect and you will not have to roll fender lips.
Thanks for the confirmation Craig. I know you did a lot of checking things to get yours setup just right so I appreciate your input. I'm gonna pull the trigger on these.
