Driveshaft Clunk
21 replies to this topic
RTWildChild
RTWildChild
  • 200 posts
1-3 months ago, I installed a 1 piece aluminum driveshaft. Recently, I've noticed a clunk when the car is slowing/winding down to a stop, or starting to roll/barely move forward.
I am assuming, the differential is getting weak? Any thoughts? Anyone have this problem before? Or is this normal operation for a one piece DS?What would I want to look into to prevent this from happening or am I more or less looking at needing to upgrade the differential?
Also, for my future reference, any recommendations of a specific type of differential or heavy duty parts?
Thank you as usual, learn a lot from you guys.
Mopar muscle 73
Mopar muscle 73
  • 488 posts
Take a look and see if the bolts on the drive shaft are loose.
GFYH
KeavDog
KeavDog
    Lifetime Jack Wagon
  • 4,163 posts
Check the pinion bolt on the diff/rubber isolator. I had the same issue and there was another thread on this subject recently.
Sounds like a hammer hitting under the rear seat when you let off?
John
  • 10,287 posts
Yup. I have the exact same noise. Just cropped up yesterday. I'm going to check the pinion bolt and the u-joint. Hopefully it's the u-joint as I have a one piece on the way.
RTWildChild
RTWildChild
  • 200 posts
.... Sounds like a hammer hitting under the rear seat when you let off?
^^^ Exactly what it sounds like
Definitely will be sure to check the above when I put the car up on the lift to take the clutch off to send back to McLeod
SRTROB
SRTROB
  • 77 posts
What is wrong with the Mcleod clutch?
RTWildChild
RTWildChild
  • 200 posts
Not to sure. Been having engagement issues/notchy shifts. Seems like a pressure plate issue, going to send it back to them and they'll let me know the exact details of it.
  • 14,965 posts
http://modernmoparfo...nk/#entry442710
Sounds like what mine was doing.  That bushing was toast.  Glad it was a very easy fix.
RTWildChild
RTWildChild
  • 200 posts
Thanks Jay. I'll be reviewing your vid here shortly to see what I'm up against if that is where the issue should be.
brucer41
brucer41
  • 431 posts
Same issue as Jay, bushing was completely shot. Replaced it and noise was gone
2009 Challenger SRT8 (Hemi Orange Pearl)
81iQdDzNLYL. SL1500
  • 10,287 posts
Just replaced mine. Air tools FTW. Top was pristine, bottom, not so much.
  • 1,882 posts
Cool... Did it fix your noise??
10.93 @ 125.6
  • 10,287 posts
Yessir!!
Getting that top isolator out was the only real hard part...especially to have it come out looking brand friggin' new. lol
  • 1,882 posts
Thanks!
10.93 @ 125.6
BlackAce
BlackAce
  • 26 posts
I'm having the same issue where did you get the isolator from, dealer?
QwickSilverC
QwickSilverC
  • 100 posts
Andy at Eastcoastmoparts will have them I'm sure
  • 10,287 posts
Online. Bet East Coast Moparts has them.
04578191AA
04578085AA
Those are the part numbers for the top and bottom. There is a trick to getting the top one out, once I figured it out, it really is no more than a 15-20 minute job start to finish...if you have air tools.
brucer41
brucer41
  • 431 posts
Steve White has them, got three sets from there earlier this year
81iQdDzNLYL. SL1500
tomoro
tomoro
  • 100 posts
I have same noise and same driveshaft...
clunk is solved ?
I noticed my 4 allen bolts loosen constantly.... the bolts is bolt-in spacer on my getrag...
300c 2007 5.7 hemi
PAXTON NOVI 1200 @ 8psi
5.7 Superstock full weight record : 12.706 @ 105.73
5.7 ''cam only'' full weight : Best 60':1.663 Best ET: 12.439 Best mph: 111.77 DA 858
5.7 ''cam+novi'' full weight : Best 60': 1.49 Best ET: 11.45 Best mph: 117.12 DA 926
Cam
Cam
  • 1,456 posts
Use blue loctite.
