Driveshaft Clunk
Posted 02 May 2016 - 12:12 PM
I am assuming, the differential is getting weak? Any thoughts? Anyone have this problem before? Or is this normal operation for a one piece DS?What would I want to look into to prevent this from happening or am I more or less looking at needing to upgrade the differential?
Also, for my future reference, any recommendations of a specific type of differential or heavy duty parts?
Thank you as usual, learn a lot from you guys.
Posted 02 May 2016 - 08:18 PM
Posted 02 May 2016 - 11:25 PM
Sounds like a hammer hitting under the rear seat when you let off?
Posted 03 May 2016 - 06:10 AM
Check the pinion bolt on the diff/rubber isolator. I had the same issue and there was another thread on this subject recently.
Yup. I have the exact same noise. Just cropped up yesterday. I'm going to check the pinion bolt and the u-joint. Hopefully it's the u-joint as I have a one piece on the way.
Posted 03 May 2016 - 06:32 AM
.... Sounds like a hammer hitting under the rear seat when you let off?
^^^ Exactly what it sounds like
Take a look and see if the bolts on the drive shaft are loose.
Definitely will be sure to check the above when I put the car up on the lift to take the clutch off to send back to McLeod
Posted 04 May 2016 - 05:19 AM
What is wrong with the Mcleod clutch?
Posted 04 May 2016 - 10:33 AM
Not to sure. Been having engagement issues/notchy shifts. Seems like a pressure plate issue, going to send it back to them and they'll let me know the exact details of it.
Posted 04 May 2016 - 11:47 AM
http://modernmoparfo...nk/#entry442710
Sounds like what mine was doing. That bushing was toast. Glad it was a very easy fix.
Posted 04 May 2016 - 04:05 PM
Thanks Jay. I'll be reviewing your vid here shortly to see what I'm up against if that is where the issue should be.
Posted 06 May 2016 - 09:13 PM
Same issue as Jay, bushing was completely shot. Replaced it and noise was gone
Posted 15 May 2016 - 12:33 PM
Posted 15 May 2016 - 02:33 PM
Just replaced mine. Air tools FTW. Top was pristine, bottom, not so much.
Cool... Did it fix your noise??
10.93 @ 125.6
Posted 15 May 2016 - 02:35 PM
Yessir!!
Getting that top isolator out was the only real hard part...especially to have it come out looking brand friggin' new.
Posted 20 May 2016 - 09:14 AM
Thanks!
10.93 @ 125.6
Posted 26 May 2016 - 06:45 AM
Posted 26 May 2016 - 08:41 AM
Posted 26 May 2016 - 08:59 AM
Online. Bet East Coast Moparts has them.I'm having the same issue where did you get the isolator from, dealer?
04578191AA
04578085AA
Those are the part numbers for the top and bottom. There is a trick to getting the top one out, once I figured it out, it really is no more than a 15-20 minute job start to finish...if you have air tools.
Posted 27 May 2016 - 12:09 AM
Steve White has them, got three sets from there earlier this year
Posted 15 June 2016 - 06:54 PM
1-3 months ago, I installed a 1 piece aluminum driveshaft. Recently, I've noticed a clunk when the car is slowing/winding down to a stop, or starting to roll/barely move forward.
I have same noise and same driveshaft...
clunk is solved ?
I noticed my 4 allen bolts loosen constantly.... the bolts is bolt-in spacer on my getrag...
300c 2007 5.7 hemi
PAXTON NOVI 1200 @ 8psi
5.7 Superstock full weight record : 12.706 @ 105.73
5.7 ''cam only'' full weight : Best 60':1.663 Best ET: 12.439 Best mph: 111.77 DA 858
5.7 ''cam+novi'' full weight : Best 60': 1.49 Best ET: 11.45 Best mph: 117.12 DA 926
Posted 15 June 2016 - 09:52 PM
