Forging My Drango - "the D Is Silent Mutha#\'(÷="
Figured I'd share my info on my build. Forging out a 5.7 to replace my stock 5.7. Basically wanted to lean out the AFR and run 12lbs boost. 2012 Dodge Durango RT.
Currently my mods are:
2.9l Whipple, Whipple intercooler, Whipple IC reservoir, Whipple heat exchanger,
63lb injectors,
180 degree theromostat
MSD BOOST-A-PUMP,
FastDan throttlebody,
AIS water/methanol dual nozzle w/ 3 gallon tank,
AEM Progressive H2O/Meth controller,
Snow Performance solenoid,
ARH 1 3/4" Headers w/ highflow cats,
Flowmaster 3" American Thunder Dual Exhaust,
auxiliary 5 x 20 trans oil cooler,
full size auxiliary battery,
Stinger battery seperator,
MTX-L AFR gauge, AutoMeter boost gauge,
Diablo Trinity tunner,
HEMIFEVER tune.
With the forged build I'm adding:
MMP Drop in 5.7 pistons and rods kit
MMP Forged 6.1 crank
MMP Supercharger Camshaft
MMP vlv spring kit
MMP Cam Phaser Kit
Cometic 5 layer head gaskets
Cometic exhaust gaskets
MMP 10QT oil pan
Ported and polished heads
Hy-Tech Johnson racing lifters
Upgraded flexplate
SuperStreet Stage 2 vlv body
Edge 2800 stall torque converter
Currently talking with local trans shop about forging my 645RFE
Aeromotive Phantom 340 Fuel pump system
Sent from my VK815 using Tapatalk
Dude that rocks, should be one fun ride when it's done. I'd like to make one suggestion though, ditch the boost a pump and get a real system. All that work and not having a reliable system just doesn't make sense at all.
I'll send some pics as soon as I can figure out this upload madness.
Yeah I'm working on it. No one makes Drop in fuel system upgrades for the D. I'm pretty much redesigning my own. First I have to settle on return vs returnless or keep the oem returnless system and pipe in the Aeromotive as a return system with separate regulator.
I think I got pics figured out. Probably not.
Yeah! Now we're cooking with gas!
More pics
More pics
By the way, found some good gouge on another post. Apparently when dodge performed the ECU fuel relay recall they completely cut the internal relay from the system. I'd been using that relay fuse spot via a add-a-fuse for my boost-a-pump for over a year! It's a completely dead fuse spot. I had no idea until reading that post two days ago. lol.
Figured I'd give an update. Motor installed and running. Tuning has been a nightmare. Decided to try a local tuner. He's looked at the email tunes and told me they are all wrong for the cam. Going to start tuning via wideband in January.
First I had the aeromotive phantom 340 wired into the pcm, cloning the OEM external relay. It worked fine. Brought the fuel pressure up to 65psi static. The tune had me so turned around i deleted that setup and went with the aeromotive digital fmu. It's designed to work with an inline auxiliary pump but I have it running my intank 340.
Running an old tune at the moment. Fuel trims are all jacked up. -33 on the pass. side and -22 on the driver bank.
Pulling hard enough to break traction on my AWD even without a tune. Went fishtailing across the street. lol. A monster is born!!! Haaaaaa!!!!
Sent from my SM-G920V using Tapatalk
