huh? well the long stroke of the 440 causes the electrodes to go into a hyperpsychloidal fibulations, due to this phenom it was beneficial to set the gaps at a mean value of the perogial/apogieal synusoidal swings squared, also aligning all electrode angles with the constelation Orion nets up to an additional -.2. goodmorning
Spark Plug Info!
#61
Posted 20 January 2013 - 08:56 AM
#62
Posted 20 January 2013 - 09:17 AM
Is there a switch on here somewhere for English Morning to ya too.
#63
Posted 21 January 2013 - 06:33 PM
Gotta ask if there is any proven benefit with any type of indexing as in enhancing flame front ? I do know a 440-6PAK I once had the reigns of would without question run measurably better (hundredths) (no dyno runs) with the gap a few degrees towards the exhaust vs a random 8 plug change. No boost, 1 non centered plug, low power in comparison to some of these things but still my grey matter is a wondering about their orientation and effect if any ?
This is a good question Geoff and something I've wondered about myself.
#64
Posted 21 January 2013 - 08:51 PM
Here is a clip that explains indexing. Too bad he used dirty heads. Would be able to see better with a new head.
Here is one on how to do it when you can't see the plug. Skip to... 2:00
This racer swears by indexing.
Aj, Andy, Mike OST what say you?
530 rwhp 458 trq
Posted 22 January 2013 - 09:00 AM
530 rwhp 458 trq
Posted 10 March 2013 - 10:09 AM
Here is some info I obtained today regarding spark plugs.
We have a ton of customers who use 1 step colder plugs on their srt8's for use with strokers or Superchargers or basically any combination that nets them around 500rwhp. The plug most often used is listed below.
NGK-LZTR6AIX-13- Stock number 2315- 1 step colder for 6.1
Projected tip, Iridium
Now that we have been porting 6.4L heads left and right, I have a ton of 6.4L spark plugs in a box and I wanted to determine how they compared. Here is that part number.
NGK-LZTR6AP-11EG
The 6.4L plug is the same heat range as the 2315 plug listed above which makes it a good plug for 500rwhp applications. The differences are that the 6.4L plug is platinum and not iridium, it comes gapped at .044" instead of .052" like the 2315 plug above and it has a 10k ohm resistor instead of a 5k ohm resistor. Evidently 5k is industry standard but 10k is supposed to increase plug life.
Anyhow, just wanted to let everyone know that there is a new option available for a 1-step colder srt8 plug for 500rwhp applications. This will not work with the Eagle cylinder head as it has a washered seat plug and not a tapered seat plug like the 6.1 and 6.4.
For Eagle Heads
Stock Eagle Plug: NGK SPLZFR5C11
1 Step Colder: NGK ILZFR6D11 (Stock #1208) or NGK LFR6AIX-11 (Stock #6619)
1.5 Step Colder: Brisk ER14YS
2 Steps Colder: NGK LFR7AIX (Stock #2309)
So where is the best source for the NGK SPLZFR5C11 (stock plug)?
Autozone don't seem to stock them but Oreilly has them for 4.49.
#67
Posted 10 March 2013 - 12:34 PM
Arrington aluminum 426. Twin 67mm turbos. Nitrous outlet direct port
Paramount driveline
9.20 @ 152.42mph 1/4
5.29 @ 133 1/8 1.25 60'
#68
Posted 10 March 2013 - 02:36 PM
#69
Posted 17 March 2013 - 08:33 PM
I'm going to ask a dumb question: why are folks changing the plugs so soon? At 16 plugs it ain't cheap...
#70
Posted 18 March 2013 - 10:12 AM
I've only changed mine once and went to NGK 6619s in my Eagle heads. One step colder and gasket seat.
#71
Posted 22 February 2014 - 08:40 AM
Bump for spring... I'm still bouncing between the 7787 (copper) or 6619.
#72
Posted 22 February 2014 - 09:22 AM
6510'S ARE ON BACKORDER EVERYWHERE.
fucking sucks.
#73
Posted 22 February 2014 - 09:32 AM
9.93@135mph w/200 shot 10.55@128mph NA, 6.0L/366cid
2013 & 2014 MSHS SuperStock and 2014 MSHS Index Season Co-Champion
2015 MSHS Bracket Class and Modified Class Season Champion
Spec'd and tuned by Hemituner, Paramount 8.8, DriveShaftShop, Nitrous Outlet
Arrington , Precision Shaft Technologies, TCE, GTP Porting, Rossler, Pro Torque, Kooks, Legmaker, M/T, Corn fueled!
#74
Posted 22 February 2014 - 09:37 AM
I know who has them ![]()
#75
Posted 22 February 2014 - 09:41 AM
fucking sucks.
How many sets you want? I have 2315s and 6510s on the shelf at all times... I also carry brisk as well but now that the new vettes use the same plugs as us the local GM performance shops have been buying them up... Might be why there is a shortage of 6510s..
#76
Posted 22 February 2014 - 05:38 PM
I'd go for the 6619s. They worked well for me. I just went to a NGK 2309 (2 step colder) based on Mike @ OST reading my plugs.
#77
Posted 23 February 2014 - 07:40 AM
#78
Posted 24 February 2014 - 10:29 AM
I have a full set of brand-new 2315's I just got from RockAuto before I read this thread! I'll be sending them back this week, or I can send them to whoever wants them. $115 for the set, which includes shipping.
#79
Posted 24 February 2014 - 11:59 AM
Yep, I just pulled the trigger.
