Spark Plug Info!
78 replies to this topic
#41
KeavDog
KeavDog
    Lifetime Jack Wagon
  • 4,167 posts
So what is the read on those plugs - clearly fouled but what caused it? To rich?
I've got a set of the NGK 1 step colder iridium plugs. What should I gap them at given an 09 5.7 stock block with a maggie @ 8 PSI?
Thanks,
John
John
#42
  • 10,316 posts
The material isnt as important as the heat range.
Thanks Andy! I was going to to 1 step colder, just wasn't sure if copper or iridium was better or even mattered.
#43
  • 15,021 posts
Thanks,
John
.032 - .034 for that boost
Make sure you use the proper gapping tool for iridiums. Info on my site of course.
#44
Andy@PWR
Andy@PWR
    PARTS GUY
  • 4,608 posts
What he said
KeavDog
KeavDog
    Lifetime Jack Wagon
  • 4,167 posts
Gracias. Already watched the video
Got the tools. Love the magnetic plug socket.
John
#46
  • 15,021 posts
Yeah, it's a life saver in these cars with the deep wells.
#47
  • 12,741 posts
My litlle socket has the rubber insert. I only tried one so far it worked fine. I waited till I got a wobble extension before I di them. Some of them look like they could be a bitch W/O the wobbler.
  • 8,251 posts
Rubber insert works fine for me to. And yes the wobbler helps a LOT! A tilting head (?) ratchet helps a bunch as well.
#49
  • 12,741 posts
Yeah not like I used to do back in the day. Stick the flat Gap in and Smack the plug lol That would not work out so well with these little treasures.
  • 18,597 posts
Money well spent if you're gapping 16 plugs...
http://www.summitrac...rts/SUM-900313/
I agree it's the heat range, Sean. Hell, there's nothing wrong with copper plugs if you can find them in the right heat range. I'm also not bothered by having used a 6.1 tapered seat plug on the Eagle heads (i.e. not a crush washer) as long as you keep using them...hundreds have had zero issues doing so. I'm using the Brisks simply because of compound boosting (blower and spray) and the blower at 12-13 psi at peak while spraying a long way. Nitrous Outlet can give you great advice on heat range. I never got my head around why the 5.7 HEMI's plugs were a range hotter than the 6.1's of the same year so my only question would be do you step down 1 or two ranges from the stock 5.7 plugs for your application.
vroom vroom...
#51
  • 10,316 posts
I went with the NGK 7787's....one heat range colder and copper.
#52
  • 18,597 posts
You'll be fine and the price is right. Just make sure you get good advice on the gap and take a good caliper to whatever gapping tool you use. And no, I'm not referring to Jim... lol
vroom vroom...
#53
  • 8,251 posts
That's a neat tool. I've always just used my trusty Craftsman keychain tool!
#54
  • 10,316 posts
lol @ Sam! I've got my good ole Craftsman spark plug gap and feeler guage tool that my dad gave me when I was 8 or nine......gapped many a set of points and even more plugs with this bad boy...
#55
  • 15,021 posts
I got these and love them.
http://www.amazon.co...5161&sr=8-3
I use that same exact tool Sean, although mine's a little...ummmm cleaner lol
#56
  • 10,316 posts
^^^^ lol lol
The feeler gauges are way rusty...haven't used them in a while. I'm just glad I've had it for almost 40 years. lol
#57
  • 8,251 posts
I got one of those too! I bet mine look more like Sean's than J's. I think it right there in the drawer next to my timing light!
#58
Roomraider
Roomraider
  • 2,266 posts
Now that we have been porting 6.4L heads left and right, I have a ton of 6.4L spark plugs in a box and I wanted to determine how they compared. Here is that part number.
NGK-LZTR6AP-11EG
The 6.4L plug is the same heat range as the 2315 plug listed above which makes it a good plug for 500rwhp applications. The differences are that the 6.4L plug is platinum and not iridium, it comes gapped at .044" instead of .052" like the 2315 plug above and it has a 10k ohm resistor instead of a 5k ohm resistor. Evidently 5k is industry standard but 10k is supposed to increase plug life.
So if this works for the 6.1, then which iridium plug & gap should be used for a blown 6.4?
Tuning: A.J. "HEMITUNER" Performance
Sigpic IMAG0760
Sigpic Norwalk 2013 (3)
10s.gif 10.76 @ 130
Arrington:  Aluminum 449 C.I. Hemi
Whipple:     4.0 L Supercharger
RPM:            Built Viper Spec 6 Speed
RAM:            900 S Clutch Package w/ Billet AL Flywheel
DSS:             Ford 9" Strange Pro Nod 392 Wavetrac
                     Carbon Fiber Driveshaft / 1400hp Axles
Pedders:      Suspension
#59
  • 8,251 posts
I wish I could find the NGK's around here. No one stocks them in anything other than the stock ranges.
#60
Pat McCrotch
Pat McCrotch
  • 458 posts
Gotta ask if there is any proven benefit with any type of indexing as in enhancing flame front ? I do know a 440-6PAK I once had the reigns of would without question run measurably better (hundredths) (no dyno runs) with the gap a few degrees towards the exhaust vs a random 8 plug change. No boost, 1 non centered plug, low power in comparison to some of these things but still my grey matter is a wondering about their orientation and effect if any ?
