2012 R/t Bad Miss When Cold
#81
Posted 10 January 2012 - 08:37 PM
Vince
#82
Posted 10 January 2012 - 09:39 PM
Deliver the car in the morning with a couple of LEMON signs taped to the front, side and rear windows.
I hope it all works out for you mate.
530 rwhp 458 trq
Posted 10 January 2012 - 11:22 PM
Posted 11 January 2012 - 08:41 AM
#85
Posted 11 January 2012 - 10:06 AM
#86
Posted 11 January 2012 - 10:08 AM
Slowest supercharged Challenger. Ever.
#87
Posted 11 January 2012 - 07:31 PM
Vince
#88
Posted 12 January 2012 - 10:28 PM
#89
Posted 12 January 2012 - 11:24 PM
On a lighter note...
Posted 13 January 2012 - 09:10 AM
How many PID's are you recording? The data can be lumpy but I'm a bit surprised the gap is 1.2 secs. You try datalogging with the Pred hooked up to a laptop to see if you have any more joy? Unfortunately, I have not found a setting where you can adjust the granularity of the logs. The Trinity is not as granular as it could be either. Perhaps it's the output (i.e. the PCM)...dunno.
Sorry, I should have reminded everyone I'm not using the Diablo,(which is why I ask about data rate). I'm using a simple Code reader with data logging capabilities.It is the Equus Innova 3130. It's a great tool but I'm sure the diablo is better. I am logging 21 PID's in open loop. The data may tell us something though as my rpm does drop when I take off, I just want to be sure it's not a normal drop when the clutch is disengaging. Here are the sensors being monitored.
time
rpm
timing advance
absolute throttle
speed
coolant temp
%long term fuel trim bank1 & 2
%short term fuel trim bank 1 & 2, (B1-S1), (B1-S2), (B2-S1), (B2-S2)
intake manifold absolute pressure (inHg)
calculated load (I would love to know what this is!!!)
Oxygen sensor outputs in voltage for B1-S1,B1-S2,B2-S1,B2-S2
intake air temp
and time since engine start
I'm not sure what is the best way to present the data, the Equus interface leaves a lot to be desired, however, I have populated an Excel sheet with the three seconds of data which covers the "event". Can we drop an Excel sheet in out post?
#91
Posted 13 January 2012 - 09:31 AM
I bet there's someone here who does...all you guys are awesome.
#92
Posted 13 January 2012 - 09:47 AM
#93
Posted 13 January 2012 - 09:50 AM
#94
Posted 13 January 2012 - 09:56 AM
#95
Posted 13 January 2012 - 01:59 PM
The amount of pids recorded effect the granularity of the logs. The CAN BUS can only support so much data and it's a queue type setup where it sends one signal, then the next, next, etc. The more pids you record the worse the granularity. From memory I think it takes .4 seconds per PID on the Trinity. If you need exact on the Trinity vs. laptop I can go dig up some logs and have a look. I believe the .4 is more a limit of the can bus than the Trinity itself though.
So Speedy, are you saying that each PID (Parameter-Identification-Data, if that's correct) GROUP takes 400 milliseconds? Or each sensor's response? My code reader is grabbing each group every 1.2 seconds. If the Diablo grabs each group(21 sensor inputs) in .4, then that would be 3 times the data I can record and view. That would be much better.
You could derive a nice graph from your sheet in excel and then post that.
I could, but which data to graph? There are 21 columns...better to attach the workbook and let the viewer plot.
I get your point, graphing excel data's a cinch.
Try the 'more reply options' attach file feature.
Tried that but it won't allow the excel workbook to attach.
Perhaps I'll just type out what I think is interesting and we can discuss.
I'll work on that tonight, back to work...
#96
Posted 13 January 2012 - 02:57 PM
#97
Posted 13 January 2012 - 05:16 PM
vroom vroom...
