6.4L Cam And Eagle Meanstreet Heads = 100Hp? Really?
Posted 15 August 2012 - 06:35 PM
Post #1:
Originally Posted by Back N Black:
Just finished the Cam and head install on my R/T. went with Performance Werks Racing Eagle Meanstreet heads and an OEM 6.4 L cam with phaser limiter..ran into a few obsticals along the way but finished her up last might around midnight. Here is a video of the finished product. Hope you enjoy the sound.. I know i do.
Post #7:
I haven't dyno'd yet but it feels pretty strong.. the Vendor said it would be close to 100HP at the wheels. Not sure if it is that much but the dyno will tell the truth.
All posts are from here:
http://www.challenge...ead.php?t=84094
Posted 15 August 2012 - 10:09 PM
Eagle OEM: 188/205 530/517 115LSA
Comp 274: 226/234 619/612 116LSA
Dodge 6.4: 215/221 600/566 121LSA
Obviously the camshaft is a good bit smaller with a much wider LSA which helps with tuning and drivability. Lets assume we get half the power out of this $75 camshaft compared to the $850 camshaft, that will net us roughly 50rwhp plus 25-30rwhp for the heads and there you have 75-80rwhp or 100hp at the crank and I think thats conservative. The 6.4L camshaft is drastically larger than the oem Eagle camshaft and I think 50rwhp is definitely doable from a cam only swap. I guess only time will tell.
Posted 16 August 2012 - 06:15 AM
Posted 16 August 2012 - 07:11 AM
Will the 6.4 cam go in an Eagle 5.7 with nothing done to the heads or valvetrain?
I think that is the case and if so 50 rwhp from a simple cam swap would certainly seem like a great mod. You would still have to get it tuned but the expense should be minimal compared to many other mods.
Posted 16 August 2012 - 07:14 AM
Posted 16 August 2012 - 08:11 AM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 16 August 2012 - 08:15 AM
You will need springs.
I always swapped in new lifters and springs when doing a cam swap on the older Mopar engines so generally figure on that. Do you just change to the 6.4 springs? How about lifter replacement ?
Posted 16 August 2012 - 08:16 AM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 16 August 2012 - 08:27 AM
Posted 16 August 2012 - 08:31 AM
That was more directly what i was concerned about. Still, pretty cheap hp.
Posted 16 August 2012 - 08:59 AM
Posted 16 August 2012 - 09:14 AM
Posted 16 August 2012 - 09:22 AM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 16 August 2012 - 09:50 AM
Posted 16 August 2012 - 10:22 AM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 16 August 2012 - 10:37 AM
Posted 16 August 2012 - 10:42 AM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 16 August 2012 - 10:51 AM
Most of the springs we use on Hemi heads are listed LSx. Just the 918 has proven itself to be a disaster on a Hemi.
Ok understood, I'm used to 340's to 440's, I'm still trying to get a good understanding of all this modern Hemi stuff.
Posted 16 August 2012 - 10:57 AM
BFNY Performance
9515 Detroit Rd
Cleveland Oh 44102
440-787-7235
Posted 16 August 2012 - 01:36 PM
Is the Cam Phaser required for the 6.4 cam or is there good PTV clearance?
I'll ask again and rephrase the question....
Is the Cam Phaser required for the 6.4 cam and Stock Eagle heads? How about the Eagle Meanstreet heads? or is there good PTV clearance?
