Convert Vvt 5.7 To Non-Vvt?
Posted 16 August 2012 - 08:24 PM
Pros and Cons?
Cost?
Thanks.
Solo Mach-X
Roto-Fab Intake
SRT Suspension
Petty Strut Tower Brace
Custom Engine Cover
Custom Badging
BT Catch Can
Posted 16 August 2012 - 08:29 PM
Posted 16 August 2012 - 08:32 PM
Guest_HemiRob_*
Guest_HemiRob_*
X2Buy a pre vvt and be done.
Posted 16 August 2012 - 09:01 PM
Solo Mach-X
Roto-Fab Intake
SRT Suspension
Custom Engine Cover
Custom Badging
BT Catch Can
Guest_HemiRob_*
Posted 16 August 2012 - 09:04 PM
Guest_HemiRob_*
Posted 16 August 2012 - 09:11 PM
The vvt heads (Eagle) are better than the non vvt's so with the cam choices comes head work...which you would most likely do anyway.
Posted 16 August 2012 - 10:37 PM
Guest_Daparrothead_*
Posted 17 August 2012 - 10:48 AM
Posted 17 August 2012 - 11:11 AM
Posted 17 August 2012 - 11:48 AM
Andy built me a non vvt 394, and it kicks ass
You want to know what?
the only thing you need to know is that my car will never run with the same engine for more than 3 days
Posted 17 August 2012 - 11:54 AM
Posted 17 August 2012 - 11:56 AM
InferAl went to an aluminum motor
It can be done pretty easily and the tuning is much more simple.
Posted 17 August 2012 - 01:41 PM
Solo Mach-X
Roto-Fab Intake
SRT Suspension
Custom Engine Cover
Custom Badging
BT Catch Can
Posted 18 August 2012 - 05:45 PM
So what Sam is saying I can get a blower & be done with it how much & which brand & what's the con's if I did add it? Thanks!
Guest_HemiRob_*
Posted 18 August 2012 - 05:50 PM
Guest_HemiRob_*
VVT is vaible valve timingI asked once what the VVT was exactly & all I got was to hard to explain...
since I have one I'd still like to know
I suppose it's not a very good motor to have...??!
Posted 18 August 2012 - 05:53 PM
Guest_HemiRob_*
Posted 18 August 2012 - 05:54 PM
Guest_HemiRob_*
Your welcomeThanks
Posted 19 August 2012 - 07:25 PM
The cam is advanced and retarded as commanded by the PCM to maximize both power and fuel economy.
The cam gear is a phaser that works off of pressurized oil delivered by a solenoid located in the front of the valley under the intake manifold.
That's what allows you to run 12's and still knock down 27 mpg on the highway. Pretty impressive and great until you want to go REALLY fast.
Then that same technology becomes a limiting factor.
Posted 19 August 2012 - 09:44 PM
It's more accurately decribed as variable cam timing (VCT).
I enjoyed that info & it made since, I thought it had something to do with the power & fuel economy Thanks man
