gary pavao
2004 5.7 Hemi Heads
hi, i just joined this forum, i just purchased a 2004 hemi 5.7 engine out of a 2500 pick up, and i gettting it rebuilt and stroked out to a 392. can anyone tell me the size of the stock heads CC chambers ? is it 85cc ?
Thanks gary
pretty sure you should ditch them and get a set of eagles as well. while your at this stage of the game. way more head than the older 5.7s and bolt right up. you can still get the pistons to match them at this point in your build. best advise you should take unless your buying thitek or 6.1s etc...
oh hell yes. the eagles out flow about any regular aftermarket head of any brand x engine platform. they are stock factory heads off 2009 and newer 5.7 engines. truck, charger, 300c, challenger rt etc... all used the eagles from 2009 and newer to today.
im gonna use a set for a 1500hp turbo setup on mine. they flow around [email protected] lift. they are monsterous air flow and efficient. best factory head design for cost ever. even out flow ported big block mopar heads.
Couple more questions, I have a 2006 5.7 intake, will that work with the 2012 eagle heads ? will I need to change anything else to get the heads to work ? Thanks
yup get the eagle intake or the 6.1 intake either will work and fit better than the older 5.7 intake and out flow it massively. bolt deals as well unless your a truck setup. then the front cover isnt a direct bolt on.
the eagle heads have taller rocker stands and you will also need the taller valve covers for the eagle heads. the older version hit on the rocker tips.
