Hemi57
Charger Front Jack Pads
The Scat Pack has rear jack pads installed from the factory. But, there is nothing for the front. So, I ordered some from Lift Pads Pros for $24.30 and $8.45 S/H. It takes all of 10 mins per side to remove a bolt, add some Blue Threadlocker to the new bolt, and bolt in the pad. You will need a ratchet, small extension, a 15 & 16 MM socket, and some Blue Threadlocker.
OBTW - My Harbor Freight 2 ton low profile jack fits under the car.
Remove this bolt and install the jack pad and replacement bolt.
1 hour ago, NTMID8R-R/T said:
these just for the charger or can they be used on the challenger as well?
I believe they have fronts that are very similar to what I use on my Corvette.
